And if you ever compare us to BMW owners again Ima come over there and break my foot off in your ///AMG lol
Hahah, That's generally what I see go down in their forums though. Ask a legit question. Flamed. Yes I understand I can be annoying guys. I love my car and just want to make sure it is in tip top shape. I have trust issues with dealers but have now found one I trust. I just would rather not bother them and take up a loaner etc if I pull a code and its nothing major.
I am thinking it has to do with what BLKROKT said and maybe cause of my ROW boxes and Afe Filters I will get some brake parts cleaner though and spray around just to make sure I didnt fit the airboxes on with a gap in the seal.
I use a really good OBD scanner and the Torque app.
Also, got my Service BO due in 1100 miles on the dash today. Looks like Ill have to buy some parts for that. 30k miles on my C63 I bought it about a year ago now with 17k miles. Gonna put together a shopping list for the service. From what I read it is oil change, cabin filter, spark plugs, and a bunch of checks. I am also purchasing brake pads this week.
Let me know if I am missing anything but from what I read online these are the items. Im surprised about the plugs because of such low miles.
OK well here is another thing that I should probably post in a couple other threads....
Seating and screwing down the airbox properly is vital with this car, and I have had issues with it. You need to screw them down snugly but not too tight, or they will strip. The screws stretch. Yes, stretch. I have even been told by one tech that they were not intended to be reusable. I haven't verified that. But I was plagued by cels when dealing with filters/charcoals etc. Then I bought all new screws. I used thread locker, just a dab. Made sure everything was super well seated. Then I screwed them down. Starting with one. Skipped one screwed down the next one. Around like that, like lug nuts on a wheel. Problems were solved. All good since. If I started getting them again when cleaning the filter, I change the screws. Few bucks. I can usually tell the one that has gone. Try that.
Thanks a bunch! Awesome of you to add that in. Do you know the part# for those screws by any chance?
Scanned today and got same faults but one grey and one "pending" but no codes. Im cleaning the MAF this weekend if that doesnt work ill swap for original mafs from original non row box and if thats no good I'll keep trying other things, new screws for airboxes (ordered), etc. I sprayed brake cleaner around airboxes to check for leaks, nothing. I still think the heat/humidity is affecting performance too. Anyone get bog on very hot humid days? Car seems a little boggy at times but not terrible. Top end above 130 seems slower than before. Also may try to unflash and reflash again as a very last resort.
Same codes so I'm going with Maf. Are your guys maf wires touching the intake manifold? My right one seemed crimped travelling back but I'm pretty sure I'd get a whole different code if it wasn't reading a maf at all. And id likely get that coffee every time.
Just an FYI for those that dont know. It seems the Airbox screws have been updated by MB. Newer ones are black and are threaded all the way through instead of only threaded partially up the shaft.
Wonder if this is for a particular reason.
Interesting. Im pretty sure those are all I have ever known.
Not sure on this car cos I haven't pulled yet, but last ones were black threaded all the way up. I have bought a few sets though so not sure if I ever had any different. Cant recall. 3 cars, 5 years, But in my memory thats all I have ever seen.
Silver threaded halfway. Still do exactly the same thing.
I was told by a tech that the screws stretch, and are only good for a couple of uses, which would explain my inability to get a good seal the first time around. There were a couple that felt stripped but in fact were not. But for the life of me I can't recall if those looked any different. KINDA rings a bell, but can't say for sure. I have zero seating issues now tho, having used new screws.
All I am saying is what I was told. There were a few screws that definitely would not get hand tight. I replaced them, and there was no issue. Maybe they were made by the same guys that made the deadbolts lol.
No, it was a Mercedes tech at the dealership. They are aluminum, and he said they can stretch just enough the box won't snug down. Say what you like, but my problems went away when I changed the screws, and I know of others with the same experience. Not sure why it seems so far fetched.
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
I get it man. Not bashing. Just saying that they never needed to be torqued to the point that they stretch, prob why they're made out of aluminum in the first place. But I get that they're easy to overtighten, so it makes sense. I paint my screw tops black, but I'll prob get these anyway if they're black anodized or whatever.
It reminds me of the aftermarket air inlet funnels that have silicone couplers and people put clamps there (not understanding that there's absolutely no need to tightly seal that spot). Although not exactly the same concept, also completely unnecessary.
I mean, you only need the airbox covers not to pop off. The rubber filter edge seals the boxes more than enough with just a little bit of pressure from the cover.
Maybe the new ones are but the old ones are steel and if they were TTY, you'd never get the required torque to stretch them.
The new bolts are likely designed to have more thread catch the weak plastic inside the air box base. And the filter is a taper seal so you don't even need much clamping force to seal. When you changed bolts did you pull it all apart and clean everything as well?
Sorry man, that tech is feeding you heaping spoonfuls of sh¡t.
I clean everything every time, and while I haven't done it on the new car yet I have probably had the airboxes off the first
two cards probably eight to ten times. I have at least a passing familiarity with the process. It sounded like hokum to me as well, but I got tired of the lights and so I tried it - having tried everything else and being on the verge of putting back the charcoals and original filters. It worked. The screws I have used are definitely aluminum. My fathers business involved aluminum and I handled it daily.
Again, not sure why new screws helping with this sounds so incredible to people.
Yours were likely stripped then. The extra few rows of threads biting into the plastic solved it for you.
My current bolts are magnetic, if you need proof I can provide it .
So, new light weight aluminum bolts to offset the extra thread material?
