C63 AMG (W204) 2008 - 2015
Intake Manifold Gasket and PCV valve DIY
Old May 9, 2020 | 09:48 AM
  #101
Adam_'s Avatar
2012 C63 AMG
Originally Posted by c63panda
pm me if you’re within the US
Just pmd you panda thanks allot
Old Jun 8, 2020 | 02:47 PM
  #102
c63panda's Avatar
2012 C63 Coupe
No more bungs. If you can source a sprinter intake manifold, it comes with 3 bungs
Old Jun 23, 2020 | 10:09 AM
  #103
Shaheer's Avatar
2010 C63 P30
Hey guys,
For those who jb welded the plastic clip, that goes in front of the manifold, did you have any issue with it? Or does jb weld works fine?
Old Jun 23, 2020 | 12:25 PM
  #104
DRBC43AMG's Avatar
PCV valve(s) are these a N. American speciality or do all C63s have them today? I know for example that the non N. American version of the W202 C43 never had these valves.
Old Jun 23, 2020 | 12:27 PM
  #105
TPete19's Avatar
2010 C63 AMG, 2010 GLK350
Originally Posted by Shaheer
Hey guys,
Mine has held up for 3 years now. I drilled it out a bit and sleeved it with the aluminum innards of an electrical crimp connector before JB Welding it.
Old Jul 29, 2020 | 08:54 PM
  #106
iBoost's Avatar
2011 C63
For those that replaced the gasket and PCV valve, how soon after the first start up did the CEL go away? Or did you guys erase the code first and it just never came back?
Old Dec 24, 2020 | 03:57 AM
  #107
Dannyroman's Avatar
C63 AMG
Originally Posted by NaijaBerry
Almost 2 years on this post is still helping out big time! @chrisridebike8 thanks a lot for the detailed instructions you put together for this, I just finished up doing some work on my ML63 (same engine) everything went very well following instructions to the letter. The semi-disaster was one of the bolts snapped as I have a very inaccurate Torque wrench. I will redo it if I get any leaks, I've got enough Curil T in there to keep things kosher for a bit....I guess.
I just wanted to add my 2 cents as I didn't go in there because of a PCV issue (so I thought) but because I was getting multiple throttle body errors, actuator and potentiometer related. This made the car go into limp mode at will and it was unusable. So I decided to change the PCV while going in, and bought a metal intake manifold centre plate just in case I got in there and it was leaking, I had to because I'm thousands of miles away and I didn't want my car waiting another 2 weeks. Well it turns out the ML63 had a metal one in there already.
Ok so after I opened up the intake manifold to access the throttle bodies and clean them up, I saw the issue. The intake manifold was filled with oil, and there was oil all over the bottom of the throttle bodies, the oil came in through the hole the PCV connects to, good thing I decided to change the PCV!
Back cover of intake manifold removed to expose twin throttle body
Back of throttle body plate behind where the TB's attach to
Inside the chamber of the intake manifold, the PCV attaches to the top right, the oil came in through there
Well right off the bat the car started well, idled well and actuator/potentiometer errors gone, drove it around bit and so far so good! This is a far cry from 2 weeks ago where the car would just go into limp mode as soon as I start the engine, I guess the oil in the intakes stopped the actuators from performing optimally.
I did a test of the throttle bodies before putting them back together, disconnect the fuel pump and connect the battery turned the ignition on and pressed the throttle from inside and the actuators moved quite very effectively.
I thought I'd just share this as I searched for weeks and could not see anyone that had the same errors I was having, I came here to learn how to remove the intake manifold and this seems to have solved my problems all together.
Thanks again chrisridebike8
I have opened my inlet plenum for cleaning and noticed. The two black rubbers from the throttle bodies are missing , I can’t seem to find the part anywhere or even the name of these 🤦‍♂️, will this effect the engine performance in anyway thanks
Old Dec 24, 2020 | 05:08 AM
  #108
DRBC43AMG's Avatar
I checked the MB Parts Information system and didn't see the rubber seals either
Here's a copy of the diagram and parts list for info
File Type: pdf
Old Dec 24, 2020 | 06:12 AM
  #109
Dannyroman's Avatar
C63 AMG
So it looks like the two pieces that are missing from my throttle bodies are item no 10 on those drawings (described as fitting) . I wonder why these where left out 🤔 are they known for breaking also do you know if it would affect the running of the car in any way ?.
if I can’t find the gasket/ Seal could I use gasket sealer ?
thanks for your help much appreciated 👍👍
Old Dec 24, 2020 | 07:14 AM
  #110
DRBC43AMG's Avatar
Sorry can't help there. I have never opened the intake or throttle bodies area so don't yet know how it looks inside.
However I imagine that those rubber gaskets serve a purpose and I wouldn't go without them. You need to check with the dealer. I doubt they are going to be expensive, but one never knows
Old Dec 24, 2020 | 08:30 AM
  #111
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
So those are like velocity stacks sort of if you are talking about #10, they are known to break when taken on and off if you are not careful as they are plastic and can get a bit brittle and they just clip on so the clips can break. Likely someone has been in there before broke them and tossed the. What they do is help smooth out the flow of the air into the throttle body, if they are missing they likely have a minimal effect on airflow. It isn't a gasket so you could not use gasket maker on it.
Old Dec 24, 2020 | 09:36 AM
  #112
skratch77's Avatar
2005 E55
I might have a set for you. You will notice sharper throttle tip in with the stacks installed. Amg engineers know what they are doing and put them there for a reason.
Old Dec 24, 2020 | 10:29 AM
  #113
Dannyroman's Avatar
C63 AMG
Thanks for your help , yes I done some research and realised they where velocity stack/ trumpets 🎺😂 . Someone has definitely been in there before and done some shoddy work 🤦‍♂️
Old Dec 24, 2020 | 10:39 AM
  #114
Dannyroman's Avatar
C63 AMG
That would be great! Thanks.
I thought they might of been one of those over engineered items that either don’t work or not really needed like the swirl flaps on the Bmw e60 motors 😂. Turns out they break and people don’t bother replacing. Could be one of the reasons it’s idling a little bit lumpy. 👍
Old Dec 24, 2020 | 10:46 AM
  #115
skratch77's Avatar
2005 E55
While you are un there I would do 82mm tbs. Makes a huge difference in throttle response
Old Dec 24, 2020 | 12:34 PM
  #116
Dannyroman's Avatar
C63 AMG
can you recommend a supplier In the uk?
or is the a 82mm TB from another model that possibly fits 🤔. Are they also plug and play.
i cant find the velocity stacks no where
Old Dec 27, 2020 | 10:43 AM
  #117
skratch77's Avatar
2005 E55
I found 1 stack and tge 82mm are oem plug and play 550 model car throttle bodies.. like from a e550 or s550 na engines.. can be found cheap on ebay.
Old Dec 28, 2020 | 05:48 AM
  #118
Dannyroman's Avatar
C63 AMG
great thanks👍 I have found a few on eBay they all seem to be missing the velocity stacks from them too 🤦‍♂️
Old Dec 28, 2020 | 05:52 AM
  #119
Dannyroman's Avatar
C63 AMG
Is this a LSD 🤔
Can anyone tell by looking at this diff if it is a LSD 🤔
Old Dec 28, 2020 | 03:07 PM
  #120
Cwagon's Avatar
2013 W204 C63 AMG P31 Estate wagon
Definitely not a Limited slip center.
That's an open standard type center.
Old Jan 26, 2021 | 03:41 PM
  #121
esphil's Avatar
08 ML63
I've been having issues with my oil dipstick coming out and after some research it seems this PCV valve could be causing that. I've only put on about 3k miles since owning it. I ordered the PCV valve for my ml63. Apparently its a pain to access without removing the manifold as noted in the guide. However it seems that it may due to the space in the C63, I think the ML63 may have more space. Would that make it a little bit easier to DIY?
Old Apr 21, 2021 | 02:15 PM
  #122
downhiller2010's Avatar
C63
Does anyone have the bolt part number for the intake manifold side of the pcv valve? Mine was stripped from a prior owners attempt to remove with without pulling the manifold.
Old Apr 21, 2021 | 03:23 PM
  #123
Celicasaur's Avatar
W212 - E63 AMG
Same thing happened to me. I don't know the part number, but I can tell you that it has been updated with what looks like a steel bolt this time around. A trip to the dealer will have them pull it up on their screen and order it in for you.
Old May 22, 2021 | 02:24 PM
  #124
SoCalCL's Avatar
CL 63 AMG
Hi, I was attempting this DIY and the vacuum hose at the front of the IM snapped, leaving a piece inside... does any know the part # to this? I do not see any numbers on the hose or plastic. Thanks
Old May 23, 2021 | 12:00 AM
  #125
go team's Avatar
2012 C63, GL63, 1989 300CE
You can just pull the line apart from the black and blue adapter next time just ahead of that bung. There’s no part number for it you may be able to get it from a cheap Benz sprinter manifold.
