C63 AMG (W204) 2008 - 2015
What is the fastest NA C63?
Old 07-20-2016, 07:37 PM
Sidv22's Avatar
Audi A5 6MT, C63 AMG
If we can, somehow, come up with a driverless solution, another 150-200 pounds can be removed from the car ��
Old 07-21-2016, 01:10 PM
Asher4799's Avatar
2009 C63/ 2015 C63 507 coupe
Originally Posted by jrcart
Yes, I am hoping to be able to knock a couple tenth's off my current record which will push me into high 8 second category. I'm probably not going to make any attempts until this fall when air temps and DA's drop a little.
Good luck getting some 8s! Your build gives me something to push for!
Old 07-21-2016, 01:20 PM
Asher4799's Avatar
Originally Posted by mthis
Secret sauce to go 10s and trap 130.
AR LT . With x pipe and straight pips (has to be does headers as the MBH are to big and lose tq down low and cant get you out the hole to get that 60foot )
Custom ms109 race gas tune
Ram air intake and renntech airboxes
Lsd
15lbs lightweight battery
16inch wheels with c300 rotors
600 lbs weight reduction.
This set up and 45f weather will get u 10.7s@130 ALL day at mir or atco
What battery are you using and are there any issues with it running all the electronics in the car?
Old 07-21-2016, 02:40 PM
Former Vendor of MBWorld
MBH motorsports's Avatar
C63, SL55, E55, CLS55, ML63, C55
AR LT . With x pipe and straight pips (has to be does headers as the MBH are to big and lose tq down low and cant get you out the hole to get that 60foot)
Our headers do not lose torque down low. In fact they gain lots of torque down low over stock. When compared to other systems our headers gain just about the same down low if not slightly more.
Where you may run into an issue is tuning. Not all tuning is made the same, but should get you in the ballpark. This is where you can see your greatest variations in numbers.
As for the fasted N/A C63: This can be very deceiving. It all depends on where you live in relation to elevation and weather. The fastest C63 N/A might run 10.7 (guessing) on the east coast on a cool day. However that same car might only be capable of 11.2 some place else in the country.
Old 07-21-2016, 05:22 PM
ritalin's Avatar
07 Z06, 2011 c63pp
Who do you think has the best tune to pair w your headers?
I need cats but i cant seem to get you via email.
Old 07-22-2016, 09:29 AM
SonnyAMG's Avatar
C63 AMG W204
Has anyone ever changed cams on the M156?
Quick Reply: What is the fastest NA C63?
