C63 AMG (W204) 2008 - 2015
Metal Rear Fenders
Old Nov 25, 2016 | 07:32 PM
604 C63's Avatar
2012 E550 Cabrio
Fat chance of me finding anyone around here that A) I would trust, B) that has a $65 an hour shop rate and C) would finish up before the W207 model comes out.
Old Nov 25, 2016 | 07:46 PM
gzim335's Avatar
c63 coupe p31weistec stg3 SOLD,2013 C63 BLACK SERIES.
At this price a bs conversion makes more sense than this imo
Old Nov 29, 2016 | 08:37 PM
Mag1c Carp3t's Avatar
2009 C63 AMG
How so?
Old Nov 29, 2016 | 08:39 PM
Phil Chow's Avatar
W204 C63
This is still cheaper than a BS Conversion.
He's only about $4,000.00 in before paint. I reckon you can negotiate something to be around $5,000.00 w/ Paint, that's really not too bad at all.
Pricy for sure, but it's custom metal work, and you never have to worry about anything cracking or anything.
EDIT: I would add though, at this point, I would search for a BS Front w/ Fenders. I find it a bit odd to add a wider rear, and still be left with the skinny fronts IMO.
Old Nov 29, 2016 | 10:17 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Not even close. I got mine done at Harry's place. Went all the way down to bare metal like this, and got about 2" stretch on each side. It's way less expensive than you think, including the full repaint of the rear quarters.
Exactly Phil, metal is the way to go. And you can get quite a bit of stretch out of the rear quarters without adding metal. The rear fenders actually match the fronts much better now, which were already disproportionately wide compared to the original rear fenders.
Old Nov 30, 2016 | 01:13 AM
AMG3.2's Avatar
C63 AMG, P30
ROKT -- you ever gonna post pics? Super interested to see how yours turned out.
Old Nov 30, 2016 | 07:06 AM
  #32
BLKROKT's Avatar
https://mbworld.org/forums/c63-amg-w...ack-tires.html
Old Nov 30, 2016 | 10:20 AM
  #33
Kriston's Avatar
C63 AMG
Metal Fenders are the best for overall longevity IMHO. This is the next best thing aside from the BS conversion.
When we did my fenders the rears were stretched to be proportionate to the front (which were already wider as BLK mentioned)
Old Nov 30, 2016 | 10:51 AM
  #34
AMG3.2's Avatar
C63 AMG, P30
Dude. Nice! That's a hell of a tire on that rim though. Have you felt and looseness via sidewall flex in the rear? I didn't read your thread, just looked at pics so you may have mentioned it there.
No, they for sure are generally speaking.
I really think you'd ONLY want to go the HMS route if you have an extremely knowledgeable and competent body shop. How they adhere the panels to the existing fenders is the key. You get this wrong, and that's when 5 years down the line, you're susceptible to seeing panel lines etc.
Old Nov 30, 2016 | 06:45 PM
  #35
2009 C63 AMG
The shop wasn't able to stretch mine. Which is why the fenders were cut and custom metal fabrication commenced.
Old Dec 1, 2016 | 12:10 AM
  #36
Alex.currie44's Avatar
2009 SLK55 AMG. & 2022 GLA250 4Matic
Love it. Can we get a pic from the rear?
Old Dec 1, 2016 | 08:56 AM
  #37
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
Holy, man. That looks perfectly awesome.
Old Apr 17, 2017 | 06:24 PM
  #38
2009 C63 AMG
Dropped the car off at the body shop. Should expect something within the month. Meantime I got pics of the fat tires mounted.
Old Apr 17, 2017 | 06:38 PM
  #39
mr747's Avatar
c63
Mmmmmmmmmm
Old Apr 17, 2017 | 07:43 PM
  #40
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Are those 285s stretched on a 9" rim?
Old Apr 17, 2017 | 08:44 PM
  #41
brad65ford's Avatar
2020GLC63
Bad ***. Wishing there was a body shop around me to do a conversation like this.
Old Apr 17, 2017 | 09:36 PM
  #42
2009 C63 AMG
Nope. Here are the exact specs.
19x9 et35ish 265/30
19x10.5 et47ish 295/30
Old Apr 18, 2017 | 06:24 AM
  #43
BLKROKT's Avatar
Nice specs. I wish I had an extra 1/2" rim width front/back to play with. Right now I'm on 10/8.5. Next time I get new wheels for this car, I'll go with 11" in back and 9" (maybe 9.5") in front.
Are these new wheels or your old ones? Did you consider going 11" in back? You're going to have plenty of room.
Old Apr 18, 2017 | 01:02 PM
  #44
2009 C63 AMG
These are my old wheels just had them straightened out/replaced few broken bolts and refinished.
The fenders were stretched based off the poke of these wheels set at zero camber. So they are flush currently.
Old May 10, 2017 | 06:40 PM
  #45
2009 C63 AMG
So the shop finally had time to fit the front wheels.
They are a bit aggressive with the new tires. So we tried to do a fender roll/pull.
This was the most he was able to get them to stretch. Told him to do the other side so I may test drive it to see if they rubbed. Than tragedy occurred.
The front passenger fender cracked right below the body line. It was previously bent before so this wasn't his fault. But everything happens for a reason.
Car is now going to undergo a custom front aluminum widebody. So the car went from only rear custom fenders to a full widebody.
Old May 10, 2017 | 07:13 PM
  #46
BadCompany's Avatar
2014 C63 AMG Edition 507 coupe
Bummer. However, I'm pretty excited to see how the front turn out too.
Old May 10, 2017 | 07:36 PM
  #47
2009 C63 AMG
A different person will be doing the fronts since we are now dealing with aluminum. But this person did a friends car full widebody which turned out perfect. Car is being trailered there tomorrow.
Old May 10, 2017 | 08:28 PM
  #48
BLKROKT's Avatar
Well, that's good and bad I guess. We opted not to touch my fronts for exactly that reason and I can still get a 255 and probably 265 under there if needed. BUT your car will look totally mental with wider front fenders, so I bet you're looking forward to that. What size tire were you trying to get under there, and what's the rim width and offset in front?
Old May 10, 2017 | 08:44 PM
  #49
2009 C63 AMG
19x9 et37 265/30/19. Really low on KWs.
Old May 11, 2017 | 11:00 PM
  #50
2009 C63 AMG
Alright I'm sure you've all been waiting see what the car looks like with the wheels on. So here we have all the wheels on. Car is at the new shop to TIG weld custom front fender flares on, which won't take long as he plans to knock it out quick. Alignment will decide final outcome of fitment but as is the rear is all good for lots of play. I can always add spacers to perfect the fitment.
