F/S Front Strut Tower Brace /Bar
Former Vendor of MBWorld
Mazspeed (09-05-2016)
Labor Day sale is running through the week.
Everything is on sale, Ultra Racing bars, Wavetrac's Ultimate PD items.
Received 2,836 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Do you happen to have access to a set of the discontinued UR rear lower control arm braces?
#34
... are always a good time.
Does anyone know what size Torx socket for the bolts at the top of the housing? I plan to install the strut bar shortly.
Secondly, as simple as it appears, just 3 bolts per side. The bolts torque into the chassis. As for procedures, it's okay to remove all the bolts then reinstall without concern of anything misaligning or the bolts not going back in properly?
#35
They are E12 socket size.
Safest way to maintain alignment is to get a non permanent marker and trace around each of the bolts. If you have the weight of the vehicle on the ground it should not shift.
#36
curt.r (08-13-2018)
