Predator AMG's..........AMG
He only has CF trim now.
I bought these on Friday and installed them. They only had up to 4000K but because it said brilliant white daylight I thought they would do the job.
Here is a picture of the 4000K installed. Still not what I want so seems a minimum of 5000K would be right like yours came out.
Before
After
Good news it came out good I think, bad news, I still have three more left to do. lol
Here is the SLK
https://www.ebay.com/itm/Car-LED-H7-...72.m2749.l2649
Dunno specs on those, but low/high/fog generally require stronger level resistance that makes built into bulb solution rare as the heat level generated would melt the solder. I highly doubt those would work as I know the base material cost to get something to work is way more than what hesh selling for, but you can try. Also looks like your first concern is even receiving the product let alone functionality if you see the review.
Also they use 5050 diodes be which are super unreliable.
Our solution isn't cheap but it's quality and works.
So because the roads have been so bad here I wanted to get a set of reps and store my multispokes so I don't damage them on a pothole or something. I found nothing local and a cousin of mine in Johannesburg sent me a pic of these, I decided to get them hoping they will fit and suite the car and to my surprise they really look good in MHO. Had a set of Vogtland 20 mm drop installed just before I got them and the combination seems to go well together. What are nice of the reps are that they are 1/2 inch wider than the OEM 19's (think they have a more aggressive offset as well) which makes them sit more flush with the body. The rears give a scrape here and there over bumps but nothing major. I have the 17 mm spring spacers for the rear I bought from the dealers to install when I get a chance and think that it would look a bit better.
Also installed a set of these TRW ceramic brake pads which I haven't heard much about but so far so good. Only issue is when installing the fronts you have to grind the middle steel pin away otherwise it doesn't pass the middle cylinder on your calipers.
The rear TRW ceramic pads.
