Predator AMG's..........AMG
When I had my C 55 a few years ago I decided to refurbish the brake disc looks, clean it up a little and was surprised how such small thing make a huge difference to the cars aesthetics.
Before
After
So decided to tackle my 63 this weekend.
Front wheel before
Front wheel after , note: had the brake discs skimmed as there was more than enough meat on it and a new P30 rotor costs R12000 and the skim R120 and the engineering shop did a great job. Pads and rotor must still wear in.
Rear wheel before
Rear wheel after
Before
After
Front wheel before
Rear wheel before
Rear wheel after
Received 2,813 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
You know they're going to get all rusted up again, right?
Forget it, I see the painted hats and edges now. Nice.
But there's zero point polishing the surface - they get surface rust by design.
Nice work. Was that a bake on high temp paint? Also, what kind of front rotors are those? They look 2 piece with the anti-rattle clips.
They are the performance pack rotors, yes 2 piece. I used a semi gloss high heat spray you buy in a can that you use on furnaces able to withstand up to 1200 degrees Celsius and I can vouch for the product as i used it on my jetmaster braai (bbq) and after a year of heat and weather it is still good. It has it's own primer in it as well which is a great help.
12 C63BS Magno Alanite Grey, 22 X3M Brooklyn Grey, 08 BMW E93, 22 Ducati Desert Sled, John Deere 3R
Nice, I actually just started doing mine this weekend, hope to finish the last 2 today - bugs the **** out of me that they get all rusty, factory uses really low quality finish on them. I am using VHT caliper, drum and rotor paint on mine - did it 8 years ago on my 335i and still looks great today!
Before and after
Then I took a drill bit, perfect size and drilled all the old hardened bake dust that clogged the vent holes.
Looks great. What colour is your car, I couldn't decide between silver or black for the discs but my car is black so I went with the black.
Car is obsidian black, was torn also between black or silver, went silver as it was the stock color before they got rusty, but seeing yours, kinda wish I did black.
Gave the lugs a coat of silver too, they were looking all dated.
Oh anything is better than the rusty look but looks neat.
Spent my Sunday morning detailing my engine and engine bay, you see such nice AMG,s and when you open the bonnet (hood in America) there is just dust, dirt and sludge everywhere.
Very nice. Good work
shaun.barnard (11-03-2016)
Adi-Benz (11-04-2016)
Finally got my LED eyelid bulbs, WOW what an improvement to the ugly aged yellow coulered bulbs.
Even bright in the daytime.
Now to just sort the ugly yellow fogs out. I wonder if there are also LED bulbs for the fogs like this on the market or does one HAVE to go the HID ballast route?
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
There are leds for the fogs!
Lemme go searching...
https://mbworld.org/forums/c-class-w...ml#post6943507
Should be the same process. Funkwagen is a wizz
You can also use Philips Diamond Vision H7 in the fog lights. Just plug in and about 5000k. Looked good in my 2010.
Azn Optics LEDs city lights, HID main lights and Philips Diamond Vision H7 fog lights
