Winter wheels. Need advice.
Had three of them in the past... now my wife sends me pics like this:
As for the tire debate, here's a starter to point you in the right direction.
People who believe that wider tires produce more grip because of a larger contact patch are wrong. They are wrong in both that they produce more grip and that the contact patch is actually larger. All other things being equal, for a vehicle of a given weght the SIZE of the contact patch will be the same between a narrow and a wide tire. It's the SHAPE of the contact patch that changes, not the actual area. A wide contact patch is primarily about temperature management, not the total amount of friction, and also about cornering stability vs. linear acceleration. For those of you that want to get into the physics of it, here's a link to an interesting article on the subject - http://insideracingtechnology.com/tirebkexerpt2.htm - that deals with slip angles, tread deformation, etc. If you want to skip the physics part and get to the gist of it, the conclusion is that a wide but short contact patch gives better cornering performance while a narrow but long contact patch gives better linear acceleration. This is true with all tires, not just winters.
So - now that we know that the actual size of the contact patch is more or less the same between the narrow vs. wide tires (and as I said earler, wider tires are about heat mangement, deformation and slip angles), when it comes to winter tires all you have to do is look at the tread pattern on the tire (think of how the little sipes that winter tires have are positioned) and figure out what will give you better traction - a wider and short contact patch or a narrow and long one?
For those of you that are old enough to remember Linda Richman's (Mike Myers) Coffe Talk on SNL... I'm getting a little verklempt. Talk amongst yourselves.
Again man, two tire manufacturers, one of whom only makes winter tires, don't support the old belief that narrow tires are automatically superior in winter conditions.
If your claim is not that a square setup is best, why not a square setup running wider tires? I think you know what the real question actually is...
The reasons why the fronts are usually not as wide as the rears on a street-driven vehicle have nothing to with grip levels. It is about the vehicle's propensity to tramline and also chew up the fronts in a much shorter amount of time as the shearing forces across the contact patch itself during a turn are about 3-5x greater than on the rear (the fronts travel at a much tighter arc - it's why you hear the front tires "skip" on wet concrete).
Here, we are talking about the C63. Not an M3, or Porsche. The engineers at Mercedes evidently thought that a staggered setup was appropriate. That isn't the question or issue here anyways.
Again, why are narrow tires better on cold pavement and packed down snow? That is the question.
If that is not what you're asking, then I apologize as I honestly don't understand your question... I am NOT trying to pick a fight.
Why is a narrower tire better on cold pavement and packed down snow? That is the question that lead us here, not the staggered vs. square debate.
http://www.iaeng.org/publication/WCE...p2381-2384.pdf
On powdery snow or slush - which you didn't ask about - the narrower tire also cuts better through the snow / slush in order to make contact with the solid surface underneath, and this is when a narrower tire also works better than a wide one - think a sharp kinfe vs. a dull one, or a pizza cutting wheel vs. a roller... in this case it comes down to simply pressure per unit area.
This is the other part that I am hung up on. If I were to take an identical winter tire in a 225 and 255 section width adding some weight to the 225 so they weigh exactly the same. Then drag each across the ground (both with and against the tread direction) using a newton meter. You're saying they would both require the same amount of force to move?
I'm not seeing it.
You quoted the post I posted it in lol...
I understand the physics side of it, as well as the wider tire myth.
You are correct that I didn't ask about powdery snow or slush because I already stated that there is no denying that in situations where you need to cut through a material, a narrower tire is better.
Where I live, most of the time I'm on cold dry roads. We're also talking a 235 vs a 255 so the contact length should be virtually identical. In the case of cold dry roads there should be no decrease in rotational grip and a slight increase in lateral grip according to that article.
I am concerned about the same road conditions. We get massive dumps of snow here, but I don't need to drive under those conditions; I have a second car for that and typically use public transit to get to and from work anyways. What I need to deal with is the same cold dry roads.
Also, I barely touched on this in my previous posts, but the most important thing to remember about tires is that they are designed to work at a particular temperature. This is where heat management comes into play - wider tires with a low sidewall cool better than skinnier tires with a higher sidwewall. If you can't get the tires up to temperature they won't grip. If you get them too hot, you'll cook them and kill them... which is why a tire pyrometer is a very useful tool. The same principle applies to brake pads - track pads don't bite when they're cold, and street pads get cooked at the track. You need bigger rotors and pads - the wider tire in this analogy - to dissipate the heat, not because they will make the car stop any faster than the smaller ones.
I assumed, perhaps incorrectly, that we were discussing winter tires designed for cold weather conditions. Again, I assume, perhaps incorrectly, that tires designed to remain flexible and soft at cold temperatures won't have to "get up to temperature" in the same way that a high performance summer tire will, and are designed specifically for cold conditions.
You seem to be avoiding answering the question I've posed several times now.
