C63 AMG (W204) 2008 - 2015
Unusual wearing of passenger front tire
Old Nov 22, 2016 | 08:19 PM
AMG3.2's Avatar
C63 AMG, P30
Originally Posted by Sakebomb
Car has 102K Miles on it. I have not gotten an alignment on it yet but plan too.
When i purchased the vehicle a couple of months ago and got a PPI from the Mercedes dealership they did not note any issues with the bushings but i'll have them check it again when they get it on up on a rack.
Do post your specs back up here though. I'd like to see them to confirm if indeed this is alignment related or not.
Originally Posted by otakki
From what I have read so far that without a kit, toe can be changed but there is nothing you can do with camber. With camber kit outs there, you can probably change the camber. I wouldn't mess with changing the toe, though. It will really change the intended driving dynamic and feel.
Yes, with camber plates, you can adjust camber. There are also OE fluted bolts that will allow you to change camber and/or caster.
Toe does indeed change the feel dramatically. I'm running +.03 at the moment and love the feel. .15+ (Factory spec) was a bit sluggish on the steering I felt.
Old Nov 22, 2016 | 09:33 PM
Alex.currie44's Avatar
2009 SLK55 AMG. & 2022 GLA250 4Matic
He really needs to find out what the situation is, what parts need to be replaced etc. before he starts making mods.
Old Nov 22, 2016 | 09:38 PM
AMG3.2's Avatar
C63 AMG, P30
Agreed
Old Nov 23, 2016 | 12:02 AM
zcct04's Avatar
C63 coupe, Z3M Roadster garage queen
Waiting eagerly to see what the alignment check tells us. I'm betting with bbirdwell:
Originally Posted by bbirdwell
The tire looks like it has toe out rather than toe in; you can tell by the way the rubber is peeled away from the inside edge.
AMG3.2's camber pic is a great illustration of wear from excessive camber - clearly the OP's problem is more than just camber.
But I am not sure I buy this:
Originally Posted by AMG3.2
Exactly. With toe in, the outer edge would be feathered as opposed to the inner tire.
On our negatively cambered cars, the wear is always going to be worse on the inside edge. Excessive toe (in either direction) makes the wear worse and the direction of the feathering is what provides the clue as to toe out vs toe in. Make sense?
Old Nov 23, 2016 | 12:15 AM
AMG3.2's Avatar
C63 AMG, P30
Hmm. Kinda. So your saying that regardless of toe in or toe out, the wear will always be on the inside because of camber?
