C63 AMG (W204) 2008 - 2015
Winter Tire from E-class?
Old Nov 22, 2016 | 03:51 PM
bribassguy's Avatar
C63 AMG
Winter Tire from E-class or S4?
Newb question here... tried search but didn't find what I was looking for. I got some conflicting answer on the offet.
There are a pair of snow tires for sale locally that seem like a great deal... I just need to know if they will fit. I've got a w204 c63 preface lift with kw coliovers.
Seller says he had these on an e550 and gave me the specs.
Width 8"x18"
Offset ET35
Bolt Pattern 5 x 112
Diameter = 18"
Tire Size = 245/40R18 97H
Blizzak LM-60 Tires
Old Nov 22, 2016 | 04:04 PM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
I am running 245/40's that is ok, but I am running 45mm offsets and they fit nice and standard 18's are 45mm - not sure 35mm will work, they will stick out pretty far, found this article, its on a C300 - guy says 35mm offset works, but you max out at 225/40's or they rub.
http://www.benzworld.org/forums/w204...2010-c300.html
Old Nov 22, 2016 | 04:47 PM
bribassguy's Avatar
C63 AMG
There is another set that's local too... off a '12 Audi S4
Width 8J"x18"
Offset ET47
Diameter = 18"
Tire Size = 245/40R18 97V
Dunlop SP Winter Sport 3D
Old Nov 22, 2016 | 07:33 PM
Top Answer: 1
Width 8J"x18"
Offset ET47
Diameter = 18"
Those will probably fit, mine are actually off my 2011 S4 that I run, 245/40/18 are the standard S4 square setup and work fine on the C63, wheels have right hub bore, right bolt pattern and right offset. (mine are 45mm and fit fine, 47 probably will be ok, I would try one on the front to make sure it will clear the caliper though to be safe, as it depends on the shape of the face if they will clear for sure) but otherwise they will bolt on!
Old Nov 22, 2016 | 07:54 PM
tpliquid's Avatar
too poor now
what is size of the center bore on the audi wheels?
if too small then no fit.
Old Nov 22, 2016 | 07:55 PM
bribassguy's Avatar
C63 AMG
Do have pics? The one for sale look like they are factory Audi Rims.
Old Nov 22, 2016 | 08:54 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Just plastidip over that logo or somethin lol
Old Nov 22, 2016 | 10:18 PM
Top Answer: 1
Audi s4 and c63 are same center bore 66.6
Old Nov 22, 2016 | 10:22 PM
Top Answer: 1
Mine were on the Audi rotor rims, reps from tire rack, those are not s4 rims look like a4 wheel but a4 wheels fit the s4 just fine.
These are the ones I have https://www.ecstuning.com/b-alzor-pa...ur/628-2~kit1/
Old Nov 23, 2016 | 12:05 AM
Alex.currie44's Avatar
2009 SLK55 AMG. & 2022 GLA250 4Matic
47 mm offset means they will reach 2 mm closer to the suspension which will be fine.
The 35 mm will stick out 10 mm closer to the fenders and I am not certain of the clearance. You can check a wheel comparator on line.
The 47 are a no brainer.
