C63 AMG (W204) 2008 - 2015
Misfires & Check Engine Light
Old Dec 31, 2016 | 06:03 AM
  #51
Jacked a c63's Avatar
2009 C63 AMG, 2013 CLS63 SAMG, FORD F350, BMW 750LI
Originally Posted by faz492
Hey mate, My car had a vacuum leak, changed all the hoses and gaskets.
The car wont be back until Friday because they are doing further testing.
Did fixing the leak (replace hoses and gasket) fix the CEL/rough idle/power loss/weird exhaust sound and everything else?
or is there more to it than the leak?
Thanks for the update!
Sadly there are no updates for my car. It's still in the shop and they're doing tests but can't figure anything out.
Old Dec 31, 2016 | 06:16 AM
  #52
faz492's Avatar
e63 amg w212 6.3
They replaced ALL the hoses and gaskets and yes it did, they also cleaned the MAF sensors.
Yes it did fix the problem.
Apparently a leak can cause the car to run rich and cause missfires in the cylinder if the leak is big enough.
If it was a headbolt issue the car wouldnt have these symptoms.
Old Jan 1, 2017 | 08:21 AM
  #53
Celicasaur's Avatar
W212 - E63 AMG
Great news Faz! That's a relief for sure!
FWIW I think a vacuum leak essentially makes the O2 sensors panic and add more fuel, but it's usually not enough to mask the problem and so the engine actually runs lean to the point where's it's all rough and horrid. Same difference I suppose, ie it's still a fuelling issue, but just thought I'd share
Still, it's fixed now, so you can go make some skids on damp roundabouts
Old Mar 14, 2020 | 01:52 PM
  #54
tai rahmaad's Avatar
C63 AMG!
Originally Posted by hachiroku
intake manifold gasket or bad primary O2 sensors. for my car it was the O2 sensors.
did you go back and change the plugs also? Change the primary 02 sensors still miss fire on cylinder 4.
Old Mar 15, 2020 | 02:15 AM
  #55
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
did not...after changing the o2 sensors, i reset my computer and all was well. pretty much reset my computer before every startup for 2 days until i could get my car into shop for o2 replacement. after about 1-2 drive cycles the faulty o2 sensor would go from reading fine to falling way off according to my UltraGauge. seems like it would lock at the last value so then that bank would just continue o2 correction based off that last value before the computer began ignoring the faulty sensor. in the case of larger injectors this caused very poor running conditions.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Jan 12, 2023 | 01:32 PM
  #56
Mcolon414's Avatar
C63 2012 coupe
C63 2012 miss fire
I change gasket, sparks. I have tune, headers, mid pipe.
File Type: mov
