Sway Bar End Link Recommendations? Agency Power or ?
#102
Received 2,827 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
No. Done making them, just too much hassle and I don’t have the time. I left insanely detailed instructions above. Just follow that.
#103
Has anyone found a solid replacement for the endlinks yet, especially for a lowered c63. The sway bar endlinks I got with my bc coilovers are too long and I don’t have the time to build a custom adjustable setup as detailed by Blkrkt.
they don’t need to be adjustable, just fit correctly without having the “clunk”.
ECS has bunch that fit other models but after calling them, they don’t have exact measurements for me. I guess I could buy, see fitment, then return for another if they don’t fit.
much appreciated!
much appreciated!
#104
much appreciated!
much appreciated!
I was in a similar situation.
I ended up with F1 racing adjustable end links.
They're pretty beefy and no clunks.
They can make whatever length you request.
#105
Can someone please double check these before I order. I have looked through the thread and is this correct below? I have read else where there must be a minimum of 14mm of thread left in the shaft too.
Front
Front 10.25” is 260.35mm (fully closed)
Front installed 10.75” is 273.05mm
Bolt 1/2” is 12.7mm
Rear
Rear 8.25” fully closed is 209.55mm
Rear installed 8.5” is 215.9mm
Bolt 1/2” is 12.7mm
Front
Bolt 1/2” is 12.7mm
Rear
Bolt 1/2” is 12.7mm
#107
You can buy adjustable 217mm center to center and adjustable 273mm center to center with plus/minus 9mm adjustment range from Steinjager. Available in m10 and m12 and in 10mm length increments for shorter or longer.
No need to get carried away with heim joint size or drill everything for 1/2 inch bolts, even when doing competitive track events.
