CEL at full tank then clears at half tank
This has happened on 2 tanks pf gas already
i don't know much but i've got a 2010 and i've had to replace 2 o2 sensors after 6-7 years...
since your cel comes and goes with your fuel level, it may be possible that your gas cap isn't sealing up tightly when closed... maybe it needs replacing...
Hope they fix it because my warranty is about to end soon. 2013 48k miles
i would also recommend clearing your codes afterward and monitor it for a while... if cel comes up again, check the codes and see if they are the same as before.
This happens on many cars (not just Mercedes). It is a result of excess gasoline flooding a vent system. This manifests on many vehicles as a trouble code. The trouble code would indeed go away after a portion of the overfilled tank has been consumed, as the vent system gets cleared of gas AND the trouble code is usually one that goes away after the ignition is cycled off.
Overfilling can sometimes be "non-obvious":
- Pump shutoff is incorrectly set or too slow
- Pump delivery rate is set high so even a timely shutoff keeps the fuel flowing a bit too long
- Car is not level because front or rear axle is "off the concrete pad" that surrounds the pumps in an otherwise paved lot and so is lower
- Owner does not realize that you MUST stop pumping when the pump clicks off, not try for the next "even dollar amount"
- Some vehicles are also just too sensitive as a result of stacked manufacturing tolerances or marginal sensors
Try stopping the fuel flow a little early and see if the problem goes away.
Jim G
Jim G
