Weird noise after RB rotor/pad install
Jacked it up and spin the wheel and it's like the piston(s) are not retracting and the pad(s) are making slight contact with the rotor only in one section of the rotor. I removed everything again cleaned the hub to ensure the rotor was flush and still making the same noise. Could it be a stuck piston, air in that particular caliper, or a warped rotor? Any input would be appreciated.
Dan
One was glaze on the brakes because we tend to not use the brakes hard in normal day to day driving and they glaze. The other is since my car was sitting for 9 weeks while I was down south the crud on the slides may be hardened up and the calipers need to be serviced which is basically a cleaning of the slides and rails. Just saying. I also like the idea that there may be a bit of rotor warpage.
