C63 AMG (W204) 2008 - 2015
Oil leak on facelift C63 on engine block
Old May 10, 2017 | 04:29 AM
bullitt69's Avatar
c63 amg PP (w204)
Originally Posted by AMG6.3
You went through the trouble to have car inspected prior to purchasing and did not address the leak prior to purchase? Do you have a warranty? I would take car back to where ever you bought it from so they can fix it or compensate you.
Goodluck
The car was in very good shape in all other aspects, the MB dealer told me it wouldn't be anything serious so I decided to purchase the car.
It is a used 6 year old car, so I was expecting that I'll need to invest some money into bringing it to ideal shape.
Old May 10, 2017 | 07:53 AM
bullitt69's Avatar
c63 amg PP (w204)
I really hope I don't have the same problem as the one described in the following thread:
https://mbworld.org/forums/c63-amg-w204/439178-2010-c63-p31-porous-aluminum-head-leak-bottom-plate-bad-head-bolts.html
Old May 10, 2017 | 08:32 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
That's the upper oil pan (where I suggested in my first post). I'm not sure if it's really necessary to remove the engine to fix that.
Old May 10, 2017 | 08:40 AM
bullitt69's Avatar
c63 amg PP (w204)
I think it really is necessary as you can't remove the upper lower pan without pulling the engine.
The photo at the end of the first page of the thread where a guy is pointing at the place of the leak with a pen is really close to the place where the engine mount bracket is.
It could also explain why motor oil leaked out when my mechanic screwed out the engine mount bracket bolt. Oil could have accumulated in the cavity behind the bracket.
If that is all true it's really a shame, I don't really want to have my engine disassembled 2 months after buying the car.
On the other hand, I haven't noticed my car losing any oil. Maybe some oil stop leak additive can remedy the situation?
Old May 10, 2017 | 09:07 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Find out where it's leaking first and don't put stop leak in.
If it's leaking from a small spot you may not need to remove the pan to fix it.
Old May 10, 2017 | 10:11 AM
bullitt69's Avatar
c63 amg PP (w204)
you mean external repair is possible? It would be difficult to clean oil off prior to filling the gap with any solution
Old May 10, 2017 | 10:16 AM
  #32
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Tons of options. Maybe something like this will work.
https://www.permatex.com/products/ad...t-leak-repair/
Old May 10, 2017 | 10:34 AM
  #33
bullitt69's Avatar
c63 amg PP (w204)
thank you for the link!
Old Jun 15, 2017 | 08:54 AM
  #34
bullitt69's Avatar
c63 amg PP (w204)
Anyways guys, oil was leaking from one of the engine mount bracket bolt holes in the lower oil pan.
It seems that it's a production flaw as these holes aren't supposed to be through. We just like some sealant in it and it's not leaking anymore
Old Jun 15, 2017 | 12:10 PM
  #35
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Nice! Easy fix then.
Edit: Was it both bottom bolts, or just one of them?
Old Jun 15, 2017 | 03:10 PM
  #36
bullitt69's Avatar
c63 amg PP (w204)
It was the lower bolt hole closer to the gearbox. It is surprising that even these cars have production flaws
Old Jun 15, 2017 | 04:13 PM
  #37
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Were your mounts ever replaced? Are the bolts the same length? Is it possible someone used a bolt too long and damaged your upper pan casing?
Old Jun 15, 2017 | 04:19 PM
  #38
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
You know, I've heard of that happening on Mustangs before. Therefore all cars must have this defect.
Old Jun 15, 2017 | 05:09 PM
  #39
bullitt69's Avatar
c63 amg PP (w204)
It doesn't seem that my mounts were ever replaced and all the bolts were of equal length.
Old Jun 15, 2017 | 08:49 PM
  #40
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
It doesn't seems that my mounts were ever replaced and all the bolts were of equal length.
Cool, thanks for posting back with the solution.
Old Jun 15, 2017 | 11:47 PM
  #41
Alex.currie44's Avatar
2009 SLK55 AMG. & 2022 GLA250 4Matic
Old farts sometimes can recall old ways.
Put a UV oil based dye in the oil in very small quantity and it will flouresce under UV light. If it does it ain't the mounts and it will help locate exactly where it is leaking from.
http://www.autozone.com/test-scan-an..._0_0?location=
Old Jun 16, 2017 | 04:50 AM
  #42
bullitt69's Avatar
c63 amg PP (w204)
I'm glad to be of any use!
Unfortunately there are still some problems I'm experiencing with the car which I can't resolve based on the information on this forum.
Old Jun 16, 2017 | 04:52 AM
  #43
bullitt69's Avatar
c63 amg PP (w204)
I was actually planning to do exactly what you're talking about with the dye, but my mechanic and I managed to find the source of the leak visually.
Old Jul 27, 2019 | 08:55 AM
  #44
gnasher's Avatar
C63 AMG
Hi all
is it possible to change the engine mounts without lifting out complete engine?
Old Dec 31, 2019 | 09:42 AM
  #45
Veight's Avatar
Mercedes C43 AMG Estate
I'm thinking of buying a C63 so spoke to an engineer at Mercedes Benz World who experienced the exact oil leak you have. He said its because the engine mount bolt on some cars goes too far in and actually punctures the block. The only cure is a new engine.
Old Dec 31, 2019 | 11:19 AM
  #46
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
If anyone is tossing an engine because of this I will take it.
Old Dec 10, 2023 | 12:50 PM
  #47
Steven_C63's Avatar
w205 c63
That is complete horse ****. If any of these engines had longer bolts puncturing the block then it would have leaked as soon it ran for the first time. All the bolts are the same length on all the m156 built you can believe that. I recently had the same leak. Pulled out the same bolt OP did and oiled poured out. Only explanation is oil is leaking from somewhere higher or maybe it’s left over oil from a previous leak that collected in that area.
Old Dec 10, 2023 | 01:42 PM
  #48
bullitt69's Avatar
c63 amg PP (w204)
The reason for the leak is long known now for the m156 - blown gasket between the upper and lower pans.
Solution is to reseal it. Here is the video of the procedure:
View this post on Instagram
Old Dec 10, 2023 | 01:49 PM
  #49
bullitt69's Avatar
c63 amg PP (w204)
I spoke with Tasos over IG a year ago and he sent me videos explaining the problem in detail.
IG of Tasos:
https://www.instagram.com/tasos_moschatos/
Old Dec 10, 2023 | 01:51 PM
  #50
Steven_C63's Avatar
w205 c63
Solution is to reseal it. Here is the video of the procedure: https://www.instagram.com/reel/CPvbjQjJvN4/
That is not the source of the leak. The engine mount bracket is above the oil pan. It’s the bed plate. Need to remove the engine and it’s basically almost a rebuild at that point in order to re seal.
