Oil leak on facelift C63 on engine block
I purchased my 2011 facelift C63 AMG with the P30 package about a month ago. The car has 53000 km (33000 miles) on it.
When I had it checked at a local Merc dealership prior to purchase, they told me there was i minor oil leak at an unusual spot which was probably the result of spilt oil.
2 weeks ago I had my strut mount bearings replaced at a different shop and they noticed the leak as well, noting that it was probably leaking from in between the the 2 parts of the crankcase.
I asked them to wash all of oil off to see how quickly the leak would progress.
Anyways yesterday while I was getting my secondary cats straight piped I decided too peek inside again and there was oil.
As you can see it is leaking somewhere from the engine block underside the right exhaust manifold and near the right engine mount.
Does anybody have any clue what it could be and how I can get it properly diagnosed?
Thanks in advance!
The mechanic said that it's very weird that there is oil behind the engine mount bracket.
The part I am referring to as "engine mount bracket" is under numbers 10 and 5. In my case it is number 10 (right side).
I'm planning to replace both engine mounts and to remove the leaking bracket to check what's behind it.
https://mbworld.org/forums/c63-amg-w204/654633-small-oil-leak-any-ideas.html
https://mbworld.org/forums/c63-amg-w...any-ideas.html
In this car, the engine mounts are hydraulic, oil filled and when they fail, they leak oil, that's how you know they failed. Also, only one of the two mounts usually breaks, the one that is stretched.
I saw some people posting that the transmission mount should be replaced at the same time.
valjay's leak (green)
I doubt it's the same source.
Phil - I suggested PCV for you because it's pretty much a direct line of sight from the PCV (arrow in pink pointing to it).
valjay - Wrong side of the engine but it's almost a mirror image. Mount circled in green, leaking from somewhere above that in the direction of the arrow. If you don't have any smoking it could be coming from the front edge of the valve cover.
thank you for visualizing the problem, I'll get it checked according to your advice
Goodluck
http://www.mercedesmedic.com/reset-m...-instructions/
Is your car tuned? Either way try resetting the adaptations.
I did the adaptation after the the gearbox was jumping into 1st in comfort and it stopped, the slipping has got worse after that as it used to do it mainly when cold but now does it all the time. I did the adaptation again today so will see how I get on. Do you guys leave the key in? As it says some cars might need it out but I have always left it in the ignition.
The sliping has been there about 2 month, car was v5 from new nearly 4 years ago. Something is definitely slipping as you can see it on the dials and hear it from the tone of the engine/exhaust. The gearbox is changing harsh down in comfort and going up through the gears very quickly and it feels like it's slipping in the gears instead of the usual of you not feel it going through the gears in comfort.
Good diagnosing J.....you must have read all the interwebs.
