C63 AMG (W204) 2008 - 2015
Dashcam Install - wiring DIY
Old May 7, 2017 | 05:52 PM
bentz69's Avatar
'16 CLS63S
This really couldnt be easier for DIY. Save yourself a good amount of money instead of passing it off to a stereo shop or elsewhere.
Ill keep it simple. I used the blackvue DR650s-2CH with power magic pro.
Mount your camera to front and rear windshield. When mounted on the front windshield and alligned properly by using blackvues directions, you wont even see the camera from the driver seat. Then you have 2 wires. The power wire and the wire to connect the front and rear cameras. I ran the power wire along the passenger side roof liners because the battery/fuse box is on the passenger side. The wire to connect the front/rear cameras was run along the driver side roof liners. Blackvue includes a small trim tool to hide the wires.
If you decide to use the power magic pro then youll have 2 options for using a hot 12v wire. You can use either the cigarette lighter fuse OR the keyless go fuse (Im using both fuses because one is for the subwoofer/amp). Follow the wiring instructions, mount the power magic pro anywhere you like with the double sided tape, use whatever settings you like and your done.
Attached Thumbnails Dashcam Install - wiring DIY-imag0415.jpg   Dashcam Install - wiring DIY-imag0416.jpg   Dashcam Install - wiring DIY-wiring.jpg
Old May 7, 2017 | 07:15 PM
BadCompany's Avatar
2014 C63 AMG Edition 507 coupe
Nice. I want to install a good camera. Does it just attach with tape? I'm not terribly keen on attaching it to my tint if the camera burns out and I need to replace it. I've read some reviews saying they don't handle hot summer weather well.
Old May 7, 2017 | 07:41 PM
bentz69's Avatar
'16 CLS63S
Blackvue cameras have a super sticky gel like tape attached to the section that attaches to to the window. I have both the front windshield and rear window tinted so hopefully the camera holds up in the hot summer weather.
I would think that if you needed to removed the camera and didnt want to damage the tint, possible using a hair dryer on the sticky section to slowly remove it would probably work.
Old May 7, 2017 | 07:44 PM
BadCompany's Avatar
Thanks. I have all the windows done too, so I've been hesitant to pull the trigger.
Old May 7, 2017 | 07:52 PM
Mag1c Carp3t's Avatar
2009 C63 AMG
Awesome I've been lazy about getting a dash cam. Tell us about your black vue settings. Does it record 24/7 or upon motion or movement.
Old May 7, 2017 | 08:25 PM
Carbon Dated's Avatar
2019 GLE 63S AMG, 2009 C63
No doubt, dash cams are nice mods for any car. I was happily surprised by how easy it is to install in the C63.
