C63 AMG (W204) 2008 - 2015
Questions after owning 09 c63 for a few days...
Old May 18, 2017 | 11:33 AM
ChatWithaNinja's Avatar
2010 R350, 2012 CLS63 P30 (sold), 2009 C63 (totaled), 2002 ML320 (Sold)
So I've been driving for a few days and I have some questions.
When driving on the highway at speed, I notice the steering is a little floaty. When I do a casual merge it doesn't feel confident, but if I do a quick merge, its super sharp AFTER I get through the mushy zone where it feels like the rear end is playing catchup to the front.
Is this a characteristic of the car or just the alignment?
How could I tell if it has a tune on it?
If I floor the gas hard, there is a "click" feel in/under the pedal. Normal? Basically I can floor it until it stops and it does nothing (besides the acceleration, heh), but if I press a little harder it feels like a button gets pressed.
Thats all for the moment.
Old May 18, 2017 | 12:01 PM
INS1GNIA's Avatar
'13 C63 AMG P31
Push the sport mode button and see if that helps with steering not feeling as floaty.
No real way to check if it has a tune yourself, would have to take it to a shop. Or you can ask the previous owner if possible.
That "click" is the kickdown switch.
Old May 18, 2017 | 12:57 PM
zcct04's Avatar
C63 coupe, Z3M Roadster garage queen
I've had my car for a long time and never noticed that click before, but just tried and it is clearly there. I GUESS that it's a kickdown switch, but in most cases the car is kicking down long before the pedal gets to the floor.
Sport button is just for traction control, has nothing to do with steering or suspension, so unless you are I doubt that'll help.
I've never thought of this car as 'floaty'. Things to check - do you have matching tires front & rear? Are tire sizes at or close to spec? Are tire pressures at or close to spec (see fuel door)?
Old May 18, 2017 | 12:58 PM
JimGnitecki's Avatar
2012 Mercedes C63 AMG S
Car magazine road testers have commented on how GOOD the C63's steering is compared to other cars in the same segment.
And I myself, having owned a LOT of car over half a century, find my C63 to have about the most nimble and responsive steering I have ever had, and that includes owning 4 Corvettes. The only cars I have driven that were as good or better were Lotus sports cars.
It might be a good idea for you to have someone experienced with C63 driving specifically drive your car and let you know whether or not it feels right to him. There could be something wrong - or worn, since your car is an '09 model (you have not given the odometer mileage).
Jim G
Old May 18, 2017 | 01:11 PM
Alex.currie44's Avatar
2009 SLK55 AMG. & 2022 GLA250 4Matic
I have a habit of buying Benz cars used anywhere from 10 months old to 13 yr old. My current ride I got last fall at just under 4 yr and 46000 km.
For my own piece of mind I have had the older used cars checked over completely by my tech.
That includes checking all belts, hoses, fluids, filters plugs etc.
If there is a solid record of service we check what is due or pending e.g some items were due at 48 months so they got done as part of this. I do not buy cars which do not come with a complete service record.
My 2001 SLK320 was 13 yr old and had the original plugs in it after 60000km.
Alignment of all 4 corners is critical on these cars.
My bill for all of this was around $2000 for parts and labour.
Money well spent.
No disrespect to any of the guys on these pages who have more years for experience with the W204 C63 than I and they are pretty good with help but you will get a lot of inputs but none of us have enough info on your situation to be doing anything other than guessing.
If you plan to keep the car for a while maybe some consideration for a stem to stern inspection and service is worth considering including this issue.
Just a thought!
Old May 18, 2017 | 01:38 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
What tires do you have and what pressures?
Old May 18, 2017 | 02:53 PM
All good advice, thanks!
Tires are super cheap. I'm pretty sure they were put on there because when the dealer got it they were bald.
Actually, the cheap tires could very well be the reason it floats. I'm planning on getting it looked over soon - specifically the alignment.
Old May 18, 2017 | 03:22 PM
CarHopper's Avatar
E63S | X5
^If you have 2 different types of tires on the front and rear thats your problem. Basically guarantee that is your problem actually.
Old May 18, 2017 | 03:24 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
And something crazy that I've just discovered recently, is that if your front tire pressures are above 65psi, then your car will definitely ride and handle a little funny. I know, it's crazy, but you should check that too.
Old May 18, 2017 | 04:15 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
It is a kickdown switch.
Floating is probably tires.
Old May 18, 2017 | 04:35 PM
Carbon Dated's Avatar
2019 GLE 63S AMG, 2009 C63
There's got to be a story here if you want to share.
Old May 18, 2017 | 04:44 PM
BLKROKT's Avatar
https://mbworld.org/forums/c63-amg-w...-pressure.html
Old May 18, 2017 | 09:33 PM
julours's Avatar
C63 AMG w204
If your tires are good, make an alignment and the floaty feeling will disappear.
Had this issue before, MB shop had to use crash bolts to properly make the geometry. Then it's fixed
Old May 18, 2017 | 10:12 PM
I think you mean camber bolts and yes, they must use new ones each time the car is realigned. They are a one time use item.
Old May 19, 2017 | 02:49 AM
julours's Avatar
C63 AMG w204
Yes, we can also call them camber bolts or TS adjustment screw. Part number A 000 333 10 71
Old May 19, 2017 | 07:32 AM
Vladds's Avatar
2010 C63 2019 GLA45
Are you referring to specifically Mercedes, or is it a general statement?
I run these in my Subaru, did not see something about them being single use.
Old May 19, 2017 | 09:22 AM
Mort's Avatar
MB calls them a control arm bolt kit. Used for making small adjustment to the front camber or caster. Part # 000 333 10 71. As far as I know they are not single use
Old May 19, 2017 | 11:37 AM
Tlnt60's Avatar
2012 C63 AMG Coupe
Hey, I had the same feeling when I bought mine. See if you can search my post, but it basically came down to my spacers and tire pressure
Old May 19, 2017 | 11:45 AM
Great info!
I'm pretty sure the tires do match front to rear, but I will double check at lunch.
I'll be sure to mention the camber bolts, adjustment screws, or control arm bolt kit when I take it in to have the alignment done.
