500WHP C63 Edition 507 DYNO'ed
What day did u Dyno so I can look up the weather ?
The conditions on that day were EXCELLENT to Dyno a car. High baro pressure,low humidity and 57 degrees air temps
your cf should of been to lower the numbers not raise them.
There is no such thing as a magic prototype tune lol c63 don't make 450whp stock lol
A conversion formula I grabbed years ago from one of the engine dyno sites gives the following results:
SAE versus STD Dyno Correction Factors
Temperature 57
Bar Pressure 30.14
Humidity 49
SAE correction factor = 0.943012087
STD correction factor = 0.961352131
Percent STD vs SAE 1.019448365
Note that under BOTH STD and SAE standard correction, the reported raw dyno results get REDUCED via the correction to either STD or SAE standard conditions, because yes, the conditions were remarkably favorable - way better than either the STD or SAE standard conditions.
As you can see, the correction to STD standard conditions is a MINUS 3.9%, and the correction to SAE standard conditions is a MINUS 5.7%.
Under these favorable conditions, the difference between the SAE and STD correction results is only 1.94%.
But, do we actually have a dyno chart, or raw Dynojet file, somewhere in this thread showing that these were indeed the ambient conditions? if so, I guess I missed it.
I'm also disappointed in the incomplete way the "500hp claim" was presented by the OP. Normally, when you claim a "breakthrough" result, you should post "the proof" - a dyno chart showing:
- The actual true ambient conditions for the dyno run (temperature, humidity, barometric pressure)
- The uncorrected rwhp versus rpm curve
- The rwhp corrected to standard ambient conditions, either STD or SAE, but preferably SAE as that is the more realistic standard for street vehicles, and the one used by all the auto manufacturers and most tuners.
I realize that the dyno operator might initially offer only a printout of the corrected power and torque curves, but anyone claiming a breakthrough needs to also provide the raw Dynojet file (which can be easily emailed from any Dynojet dyno to any customer - don't let any dyno operator tell you anything different), so that anyone with the Dynojet software (easily downloaded for free onto any Windows computer, but not a Mac) can open the file, see the raw and corrected data, and verify that the claim is legitimate.
If a raw file is not made available,then naturally the claim will be viewed with suspicion.
Note too that even if all this is done, if an unscrupulous dyno operator / tuner looking for instant fame and sales of his tune simply puts his 98.4 degree fingers on the temperature sensor to inflate the apparent "ambient" temperature, he can make a run look much better than it actually was. That's why it is always wise when claiming a breakthrough result to have a surprisingly good result verified on a guaranteed independent dyno. Otherwise, this kind of contentious thread is what you get.
Finally, don't forget that the STD and SAE formulas assume that an engine is 100% capable of producing exactly the same corrected horsepower, when the correction formulas are applied, no matter how bad or how good the actual raw ambient conditions were at the time it is tested. This is obviously NOT true for all engines, and never true when taken to extreme ambient conditions. Real engines just are simply not that "adaptable". We all know that virtually all engines produce less power under really hot conditions. We also know that many engines will produce unusually high power under really cool conditions with almost perfect humidty and barometric pressure conditions. So, if a normally 480 rwhp engine is run at 57 degrees, 49% humidity, and 30.14 barometric pressure, yeah, it might flash a particularly good result better than the normal corrected 480 rwhp. But has the tuner actually achieved a breakthrough, or has he simply taken advantage of extreme ambient conditions to make his client feel good?
Jim G
If we had the raw files it would be easier to see but I'm sure those will never come to light.
Jim the op said it was 1.02 so how is the Dyno inflating numbers? On top of ideal excellent Dyno conditions they got it to also add 1.02 to there numbers
We have 2 things going on here.
1 really good weather conditions
2 a cf that inflated those really good conditions to begin with.
Temperature 57
Bar Pressure 30.14
Humidity 49
Jim G
Another reading of the Socratic elenchus is that Socrates is not just concerned with the reply of the interlocutor but is concerned with the interlocutor himself. According to this view, Socrates is as much concerned with the truth or falsity of propositions as he is with the refinement of the interlocutor’s way of life. Socrates is concerned with both epistemological and moral advances for the interlocutor and himself. It is not propositions or replies alone that are refuted, for Socrates does not conceive of them dwelling in isolation from those that hold them. Thus conceived, the elenchus refutes the person holding a particular view, not just the view. For instance, Socrates shames Thrasymachus when he shows him that he cannot maintain his view that justice is ignorance and injustice is wisdom. The elenchus demonstrates that Thrasymachus cannot consistently maintain all his claims about the nature of justice. This view is consistent with a view we find in Plato’s late dialogue called the Sophist, in which the Visitor from Elea, not Socrates, claims that the soul will not get any advantage from learning that it is offered to it until someone shames it by refuting it.
We tuned my car last week at Euro Charged Toronto, wanted to live with the car for a few days before posting.
Note - I have a 2010 / NON PP / Full Bolt On Car.
Numbers:
Modified V5 Tune - 465 WHP / 433 LB TQ (Dyno Run April 2016)
V6 Tune - 465 WHP / 411 LB TQ
Unicorn Tune - 467 WHP / 419 LB TQ
Just based on pure numbers, my modified V5 tune (Dyno Tuned) from last year was the strongest the car performed with the EC software. On EC Toronto's Dyno-Jet
From what I gather, Jerry and the team at EC are constantly trying to improve the M156 Software. Some decent gains were made on a select few cars over the last few months. This beta tune is geared towards cars with LTH's. The tune did not make any significant power increases on my car.
Driving Dynamics
This is where things get interesting, the car feels noticeably faster (Power delivery are VERY linear. (God what this car could be with a proper DCT or Manual Transmission). The responsiveness of the engine is the best it has ever been.
Noticeable difference from the V6 Tune? - Minimal, difference. The car feels more responsive to throttle input. This is the biggest difference.
Trap speeds will determine any gains - if any thing my experience is that Dyno's are not the best way to determine power delivery / driving dynamics. Don't let it be the end-all.
As for the OP's Car - I trust in the EC dyno and the guys at EC Toronto were just as surprised with the numbers as we are. I will maintain that the OP's car is a factory freak motor. His results are not to be taken as the norm, nor has EC stated that it will be.
That being said - I will always appreciate EC pushing the platform forward. Its nice to see an attempt being made.
Numbers:
Driving Dynamics
This is a relatively easy and effective way to make a car feel notably quicker without actually increasing its horsepower, and for a sporty car it makes sense to do.
This is in fact one of the things that the car manufacturers alter programmatically when you select a "rain" or "winter" driving setting, except they REDUCE the throttle body opening per degree of pedal movement for those rain or winter selections, to make it less likely that a driver will accidentally lose traction when the roads are slick.
Back around 2000 or 2003, there was an SAE paper on this made available on The Web.
Jim G
Numbers:
Driving Dynamics
Correct me if I'm wrong, you are still running the agency power headers?
The 507 dyno' d had MBH headers?
Not that it's worth much but on the LS7 headers with 2" primaries vs 1 7/8" make another 7-12rwhp up top. So if the cyclinder heads flow enough to make use of the 2 inch primary then there would in fact be a difference there as well.
I will see how I make out on a dyno jet 224x independent from eurocharged. Dyno before and after if I get the updated file before then.
Otherwise hitting the strip hopefully June 23 as long as nothing else comes up.
