Went in for $175 alignment and came out with $3200 bill
Installing the alignment bolts does help to explain the 3 hours they took to do the alignment. I do hope they did a good job and your car is handling well and you are enjoying it.
Front caster and camber are adjustable as I suggested by replaceing the fixed bolts with what MBC calls TS Adjusting Screws aka alignment bolts. Of course toe as we all know is adjusted by the tie rods.
Only the rear tow and thrust angle are adjustable and it influences the rear camber.
