C63 AMG (W204) 2008 - 2015
What power steering fluid is in the car and what is a good fluid for track duty?
Old Jun 24, 2017 | 05:44 PM
iownedu's Avatar
2014 Mercedes E63S AMG
Searched and came up empty. My fluid boiled over at the track today.
A: What can I buy at any old parts store to top it back off?
B: What is the best fluid to replace it with that has a higher boiling point and is compatible with MB?
Old Jun 24, 2017 | 06:01 PM
Thrilla's Avatar
Veteran: Army
2014 C63 AMG 507 sedan
Brake fluid
I'll assume you meant Brake fluid.
If you boiled OEM fluid, I'd recommend Castro SRF.
Old Jun 24, 2017 | 06:02 PM
iownedu's Avatar
No, Power Steering fluid. Already have Castrol SRF brake fluid.
Old Jun 24, 2017 | 06:22 PM
bhamg's Avatar
C63 AMG
OE fluid: Pentosin Power Steering Fluid & Hydraulic Pump Fluid CHF11S PN 975 54001 348
Fill to the bottom cold level mark and it shouldn't leak out.
Attached Thumbnails What power steering fluid is in the car and what is a good fluid for track duty?-s-l1600.jpg
Old Jun 24, 2017 | 07:26 PM
iownedu's Avatar
Thanks! Just picked up a can, says it's good to 266 degrees F. I refilled it for now, and in a few days I'll flush it out with all new using a turkey baster, then repeat again a few days later.
Old Jun 24, 2017 | 08:14 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
That's weird, never hear that on these cars.
EDIT: NEVER use ATF in our power steering system. Requires a synthetic hydraulic power steering fluid that adheres to MB 345.0
Old Jun 24, 2017 | 08:15 PM
iownedu's Avatar
Originally Posted by BLKROKT
That's weird, never hear that on these cars. The GTR guys like the Motul Multi ATF for higher temp stuff.
I hadn't either until I googled it today and found it's really common in the m156 and everyone's rectification was to zip-tie a rag around the cap. Hopefully this new fluid does the job filled to the minimum level.
Old Jul 13, 2017 | 08:22 PM
BLKROKT's Avatar
Wanted to revive this thread as I'm planning to change out my fluid and want something robust for track duty just in case, even though I've never had an issue with whatever is in there now (Pentosin CHF 11S I assume).
First of all, ATF should NEVER be used on our ps system. Full stop. It will destroy seals. End of story.
Now, seems I'm left with 4 choices for hydraulic power steering fluids that meet or exceed MB 345.0:
- Pentosin CHF 11S (OEM fill)
- Motul Multi HF
- Redline Power Steering Fluid
- Amsoil Multi-Vehicle Synthetic Power Steering Fluid
They are all synthetic and conform to MB 345.0. Here are their technical spec sheets in the order as listed above. I'm not smart enough to interpret which one would be best for heavy track duty. Can someone translate these for me? The Redline and Amsoil fluids have significantly higher flash points than the Pentosin or Motul, but are also massively more viscous at 40C and a bit more at 100C. Some of the Porsche people complained about how thin the Pentosin is, and these other two appear to solve that issue, if it even is one. I just don't know what this all means, any help is appreciated.
Old Jul 13, 2017 | 11:26 PM
bhamg's Avatar
C63 AMG
That'd be hard on the pump. Are you willing to risk that for a dubious benefit, or even no tangible benefit at all?
Old Jul 14, 2017 | 01:09 AM
BLKROKT's Avatar
I don't know, that's why I was asking. There have been some who say that during heavy extended track sessions, that the Pentosin thins out too much and destroys the pumps. Hence the more shear-resistant thicker viscosity options. They officially conform to MB 345.0, so should be fine, otherwise they wouldn't meet the spec at all.
I have the Redline on the way as it was readily available on Amazon (with a bottle of Pentosin just in case). We will see.
Old Jul 17, 2017 | 10:03 PM
BLKROKT's Avatar
Flushed out the power steering fluid tonight. I ended up using the Redline for its higher temp properties, and it's also more viscous at higher sustained temps that I see on track which should provide some added protection.
And it looks like I'll need it. First drain out of the reservoir, whatever was in there came out BLACK. I drained into an empty bottle, and light wouldn't even pass through it. No bueno. Fill with Redline, start up car, turn the wheel back and forth for a minute, shut off car and drain again. Still coming out black. Again. And again. And again. Last time it came out a bit murky, but was massively better than what was in there. Used up the entire liter of the Redline doing it, probably should have used the Pentosin for the flush, but whatever. This should last me awhile, but the PS fluid was clearly never changed.
I can tell that the steering feels much lighter and smoother already, and no noises from the rack that I had before but didn't really notice. Hope there's no real long-term damage....
Will report back on road and track performance.
Old Jul 17, 2017 | 10:12 PM
iownedu's Avatar
Let me know your results. I flushed mine about 3 times (drove the car between each flush for awhile) with Pentosin to get it clean. I am still running pentosin but filled to the lower cold mark. I have no idea how full it was when it boiled over at the track, hadn't even though about needing a better PS fluid for track duty honestly.
I haven't had it back to the track yet with it filled to the lower cold mark, there's a couple events in August I have my eye on however.
Old Jul 17, 2017 | 10:20 PM
BLKROKT's Avatar
How dark was your old fluid when you flushed it? I'm going to drive it like this for a week or two, and do it all over again to make sure the fluid is as clean as possible and all the old fluid from inside the rack is out. Pretty disappointed it was so bad.
Old Jul 17, 2017 | 10:22 PM
iownedu's Avatar
Very very dark brown, almost black.
Old Jul 18, 2017 | 12:00 PM
tfthach13's Avatar
'09 C63
Did you change out the power steering reservoir when you changed the power steering fluid? I just had my power steering serviced at my Indy and the reservoir was swapped out as well since there's a filter inside of it....maybe that's why the fluid kept coming out black?
Just a an idea.
Old Jul 18, 2017 | 12:08 PM
BLKROKT's Avatar
Just a an idea.
I heard about that filter, but did not change out the reservoir. Will do that this winter, thanks for the reminder.
Old Jul 18, 2017 | 01:31 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Isn't it just a large debris screen filter? May not be worth the effort.
Old Jul 18, 2017 | 05:36 PM
bhamg's Avatar
C63 AMG
Exactly right, it's mesh screen type filter due to the high volume of fluid that moves through the system. Black sludge will definitely form on that type of filter though, I've seen it on other cars before.
Old Jul 23, 2017 | 03:19 PM
bhamg's Avatar
C63 AMG
BLKROKT - This popped up today and I find it rather interesting (in a good way).
https://bobistheoilguy.com/forums/ub...teering_Fluid_
Old Jul 23, 2017 | 03:33 PM
BLKROKT's Avatar
Excellent, thanks for adding to the thread for reference!
First week with the fluid was uneventful. Steering feels great. Will flush again this week until totally clean just to be sure.
Old Jul 23, 2017 | 03:55 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Tempted to flush again with the Redline...
Old Jul 23, 2017 | 08:10 PM
roadtalontsi's Avatar
10 C six trizzle
Just a thought...add a decent size power steering fluid cooler?
Old Jul 23, 2017 | 09:14 PM
BLKROKT's Avatar
Yeah I know. Just add it to my never-ending list.
Old Jul 26, 2017 | 10:05 PM
bhamg's Avatar
C63 AMG
deleted
Old Jul 26, 2017 | 10:15 PM
BLKROKT's Avatar
Can't use the Amsoil ATF. Need their Multi-Vehicle Synthetic Power Steering Fluid (PSF) from the pic above. Totally different things, I think I posted a link somewhere on what ATF will do to a hydraulic PS system.
Glad I researched before dumping in Motul Multi ATF like I was originally thinking of doing.
