Spacers
Also what brand spacers do you have ?
Not sure on brand. I got the on eBay, 12mm hub centric. Also don't forget longer studs.
15mm front
12mm rear
Note that you may have to grind down your extended bolts in the rear as it may not clear the parking brake assembly. I had to grind them down 1-2mm....
I am running the exact same tire size in the rear with a 255/40/18 front and I agree 285 looks like it would fit with out any problems
Angle grinder with thin cut off disc attached.
Vice with safety jaws fitted.
The thin cut off wheels should be available at the hardware store. I never timed it but I am sure it takes less than 30 sec. a bolt. I clamp the bolts in a work mate to hold them secure and the plywood surfaces do not mar the bolt heads. You can use a vise if you have non marring clamping surfaces for it. ACG may have a good enough selection of lug bolts if you are more comfortable going that route.
