Spacers
2014 C63 Coupe
I'm running 275 35 28 Michelin PSS in the rear with a 5mm spacer on factory wheels (2015 C63 Coupe at stock ride height) with no rubbing. My set up would be roughly equivalent to a stock 255 tire with a 15mm spacer. When my 275s wear out I'll be going to a 285 30 18 in the rear with my 5mm spacers and I'm confident it will be fine (similar to stock with a 20mm spacer I believe). So, although I haven't tried it, I suspect a 15mm spacer in the rear with stock wheels and tires would work (assuming longer bolts and not lowered).
A few questions if you don't mind:
1) What size front tire?
2) Did you need the spacers to fit the tires or are those primarily for cosmetic reasons?
3) Any issues at all with ABS or traction control with the new sizes?
4) Notice any obvious speedometer issues?
