C63 AMG (W204) 2008 - 2015
Has anyone heard this noise?
Old Jul 23, 2017 | 12:52 PM
NotABaller's Avatar
2012 C63, 2014 E550
Just started car for first time in over a week. Heard the sound when car was cold and around 1k rpm. Ugly sound. Got better after car warmed.
Old Jul 23, 2017 | 12:53 PM
skhan91's Avatar
C63 AMG Affaltarbach Edition
Did it just get better or did it go away after it warmed up?
Old Jul 23, 2017 | 01:36 PM
NotABaller's Avatar
2012 C63, 2014 E550
Seems like it got a lot better but sometimes can very faintly hear it when accelerating from stop
Old Jul 23, 2017 | 01:41 PM
skhan91's Avatar
Hmmm. Does your car had the LAD?
Old Jul 24, 2017 | 10:12 AM
NotABaller's Avatar
2012 C63, 2014 E550
Yes I have the LSD. I'm pretty sure the noise is always present when accelerating, its just that I can hear it only below 1.5k rpm. Going to take to a shop to check it out
Old Jul 24, 2017 | 10:17 AM
skhan91's Avatar
Same here. Lemme know what they say!
Old Jul 24, 2017 | 10:26 AM
  #32
NotABaller's Avatar
2012 C63, 2014 E550
Thanks, will do. Did some searching and a common problem is a loose heat shield. Did you get that one checked out?
Old Jul 24, 2017 | 11:50 AM
  #33
skhan91's Avatar
i have not!! this could be a good one! is there a DIY to check this?
Old Jul 24, 2017 | 11:51 AM
  #34
NotABaller's Avatar
2012 C63, 2014 E550
It's gonna be under the car and external. If you raise it up you can access it. Then just google c63 or c class heat shield and try to locate it under the car. I'm at the shop now so I'll update when I have info
  #35
skhan91's Avatar
sounds good. just had it up on the hoist yesterday. didnt notice anything. but yea keep me posted
Old Jul 24, 2017 | 12:31 PM
  #36
NotABaller's Avatar
2012 C63, 2014 E550
Mechanic found a loose heat shield. He put it back in properly now.
Old Jul 24, 2017 | 12:32 PM
  #37
skhan91's Avatar
sweet. lemme know if the noise is gone after you drive it
Old Jul 24, 2017 | 02:00 PM
  #38
NotABaller's Avatar
2012 C63, 2014 E550
Sound is fixed!! Was a quick fix and the mechanic saw the loose plate right away.
Old Jul 24, 2017 | 03:21 PM
  #39
skhan91's Avatar
really really hoping this works on mine! taking it in tonight!
Old Jul 24, 2017 | 03:30 PM
  #40
NotABaller's Avatar
2012 C63, 2014 E550
Good luck bro. Although if your mechanic is worth his salt, he probably would have found a loose heat shield the first time around. Theyre fairly big and my guy literally saw the problem within seconds. I don't want you going in and wasting money! I snapped a couple pics so lemme post tehm for you.
Old Jul 24, 2017 | 03:34 PM
  #41
skhan91's Avatar
The guy i took it to defintely knows his stuff. hes always been spot on in the past.
i am however taking it to the dealership this time since its under warranty.
Could you PM me the pics?
Old Jul 26, 2017 | 03:45 PM
  #42
skhan91's Avatar
update:
took the car to MB.
They diagnosed it for a whole day and found:
-Diff seal leak
-Upper oil pan leak
-Tappets and cam lobes worn out (causing the tapping noise). they found this by opening up the valve covers and boroscoping a bit too.
They are replacing the cams, lifters, tappets, camshafts and resealing the diff and upper oil pan!
luckily i still have warranty on the car so after opening a technical case with MB canada, everything is being covered.
hugggggeeeeeee job!
Old Jul 26, 2017 | 04:12 PM
  #43
NotABaller's Avatar
2012 C63, 2014 E550
update:
took the car to MB.
-Diff seal leak
-Upper oil pan leak
hugggggeeeeeee job!
Wow. This is great news. What MY is your car? Do you have the full factory warranty or is it the CPO?
Old Jul 26, 2017 | 04:14 PM
  #44
AMG3.2's Avatar
C63 AMG, P30
update:
took the car to MB.
-Diff seal leak
-Upper oil pan leak
hugggggeeeeeee job!
Yikes....
Old Jul 26, 2017 | 04:22 PM
  #45
skhan91's Avatar
mines the affaltarbach edition that were the last to be produced when they were clearing out all of the cars before the FL version. MY 2011. pulled the Data sheet and the engine is outside the affected head-bolts issue so i should be good for that
But it looks like the lifters and cams issue is still very much existent until 2013+
The warranty on the car is MB CPO extended warranty and is now Power train only since its got less than a year left.
Old Jul 26, 2017 | 04:28 PM
  #46
NotABaller's Avatar
2012 C63, 2014 E550
I bought mine (2012 MY) from the owner who bought the CPO. If the CPO transfers over, then I'm going to take my car in to service for tapping noise too if they will replace my cams and tappers under warranty. Cheers.
Old Jul 26, 2017 | 04:32 PM
  #47
skhan91's Avatar
it should transfer over as long as you bought it from the person who bought the warranty and didnt buy it from another non MB dealer.
also they have to look through all your records to make sure it transfer over and all.
and then they also charge $350 to transfer it over lol.
they said it really is in the very early stages and mine has a bit higher km too (103k km) so thats why they are doing it. my dealer is super nice though and i feel like most dealers wouldnt have done it even in my case.
but tbh, if there are no signs, they will not do anything and may charge your for diagnosing it
Old Jul 26, 2017 | 04:36 PM
  #48
skhan91's Avatar
also did a bit of digging and this doc has everything!
http://australiancar.reviews/_pdfs/M...tin_200901.pdf
Old Jul 26, 2017 | 04:37 PM
  #49
NotABaller's Avatar
2012 C63, 2014 E550
I bought it from a BMW dealership that the seller sold it to. The seller and I arranged it privately but did it through a dealership so he can have trade in tax savings on his new purchase. I guess that disqualifies me?
Old Jul 26, 2017 | 04:40 PM
  #50
skhan91's Avatar
unfortunately yes. it is clearly stated in their fine print that if you purchase from not a private party, it disqualifies you from the warranty transfer.
but you could still make a case and try to have it transferred.
you could try tracking down the old owner and see if he will give you a bill of sale for a private sale? but then im not sure if you pay taxes on it again??
