Engine Oil Temp is too high? Goes up to 120c (248f)
It can be found with a search of "radiator blockoff plate", I think the thread is called "Keeping Your Cool".
EDIT: Thread here: https://mbworld.org/forums/c63-amg-w...ping+Your+Cool
The blocking plate doesn't seem to have done anything at all for my FL coupe. However, ambient temp here is almost always over 80-82F. Is there a good theory about why it's ineffective at higher ambient temps?
I've been noticing 103-109°C lately and 111-114°C when romping on it without it even being hot outside. Maybe sensor related, fan issue? I have an oil change (calculated by time) due in a few weeks. Or the b¡tch is getting ready to grenade lol.
111°C not even hot out. It's higher than I've been used to. No other changes.
Now it may not be the point where oil breaks down, but Id rather not have my oil almost at the heat limit most of the time.
I cant enjoy manual mode because the temperature shoots up so quick.
The cooling kit is expensive, and for my CLS it wouldn't fit.
A company called Vaeth, makes oil cooler upgrades which fit into the place of the stock central oil cooler. They have 2-3 versions of it depending on how much larger you want.
This is something I am ordering, and costs less than half of the 44O package.
Id suggest any other owner of an AMG with an M156 check this out.
Maybe once I get it in a few weeks I can update with observations as to how the temperature is.
I am trying the Radiator block off method soon. Some users here have posted good experiences with it. I forgot the exact number, but their oil temps dropped 5-10 degrees.
Anyone tried heat wrapping the intake?
Please post some pics once you receive the parts, and after the Install.
With how hot our cars tend to run oil, I don't think I'd mind trading off a bit higher coolant temp for lower oil temp anyway.
Plus prior to oil change it would take about 2 miles of driving to get the oil temp readout to stop flashing. Today it took almost 7 miles before it consistently stayed over 176F.
Would love to know the basis for 176F or above oil temp being "ok".
Marco
Been noticing my engine oil temp gets a bit hot. Starting it up and idling it will get to around 102 - 105c. Driving normally in C mode stays around 105c - 108c. Driving in Manual with upshifts at 4k+ and downshifts at 3-4k gets the oil temp to 120c or over. Basically cruising around with 3k rpm and some heavy feet results in 115-120c. Is this normal? I live in Toronto and the weather is usually 20-25c when I drive.
Recently did oil change and put in 10L of Mobil1 0w40, which didnt help the oil temp go down. New oil filter, KN filters, and charcoal delete. Straight piped cats with EC v6. No mods.
Also, don't know if this is related but the mechanic pulled stored codes since they were last cleared. This code was stored:
"P1061 (1061) The load limit is active."
Did lots of searching and can't find anything on this.
Take a peek at this.
http://p1061-mercedes-benz.autotroublecode.com
Compared to my CTS-V that runs at 240F I thought 212 was cool. 200 does seem cool but then my M3 racecar used to run at 190-200 while running in anger. And my IO-360 runs at 170F which is an air cooled engine.
An oil change isn't magically going to make your oil run cooler than any C63 has ever. And just to be clear, I'm not 'jealous' of your oil temp. I'm telling you that it's not even possible.
The cooling package includes the following changes:
• larger front oil cooler lying
• larger wheel arch cooler
• custom air guides
• Larger air intakes in the underbody paneling and wheel arch right
• Custom oil lines for engine and gearbox oil
