Traction Control (sport mode) cuts power in WOT second gear upshift
Anyone else experienced this? I think it may not have been TCS that cut the power when I had it in sport mode. Since in both situations (sport mode vs off), the acceleration-pause-acceleration is around 4-5k in second gear. Doesnt seem to happen in first gear.
Try doing all manual shifts in M and see if you can reproduce it.
I am beginning to suspect you might have a valved in the T hanging but not long enough to set off an alarm.
I will let some others chime in here, i have not driven the car with traction off always have it on.
Is there an option for you to take one out for a test drive from a dealer and see if it does it on that one as well?
https://mbworld.org/forums/w211-amg/...eleration.html
What they describe is very similar to mine. A lot of posters even mentioned P20D4 "The load limit is active". I think the posters in there concluded that it was load limits in the ECU and TCU.
I only noticed this happening after installing the EC v7 beta tune. Never happened on V6. Hopefully the v7 just makes too much power?
Actually, come to think of it, I think this is totally seperate from any TCS related issue. I remember just yesterday that I was doing a first gear pull with TCS on, and the TCS lights lit up all the way to third gear, with no power "cutting", just power limiting. TCS did not fully close throttle. It just limited the throttle and my car kept pulling, albeit slower than with TCS off and letting the wheels chirp.
The more I think about it, the more it makes sense that it is an ECU/TCU load limiter that closes throttle bodies upon a certain threshold being exceeded, which V7 is doing now. I haven't experienced the hesitation/jerk with TCS on. It only happened once in sport mode, and seems to be more common in manual mode. And it only happens on very violent and quick smashing of the throttle from high RPMs.
Still what you're describing sounds a lot like the transmission is having a very rough shift. I had this when I delayed getting my fluid changed and the valve body was probably partially clogged on the lower gears and possibly engaging more than one while shifting. When was the last time you had your fluid changed?
This isn't the first post I've seen about throttle issues in relations to a tune.
