C63 AMG (W204) 2008 - 2015
MCT Software Updates
Old Sep 6, 2017 | 03:03 PM
abhatti55's Avatar
'19 G63 Ed 1,'18 M5, '16 G63,'12 458 , '11 E63, Brabus SL55-K8, '10 S63, '94 E500 "Wolf", '91 560SEC
Does anybody have access to the bulletins or software updates for the tranny.
I have a '14 507 and the VMI shows it had one update done. Was not sure of anything recent.
It seems clunky and a lags. My '12 CLS and '14 S63 are much smoother. I see on STAR it doesn't allow for a wet clutch adaptation.
Old Sep 6, 2017 | 03:17 PM
NotABaller's Avatar
2012 C63, 2014 E550
Interested in this too. My '12 coupe seems clunky as well. Especially on 2-1 downshifts when coasting to stop or under braking. Can even feel/hear the clunk on the shift sometimes, it is very ungraceful and borderline worrying. My trans was serviced last year (10,000 KM ago).
Old Sep 6, 2017 | 04:49 PM
skratch77's Avatar
2005 E55
Pretty sure the twin turbo cars use a different tranny
Old Sep 6, 2017 | 05:08 PM
MTV10's Avatar
E55 AMG & C63 AMG
Still an MCT style tranny
Old Sep 6, 2017 | 06:06 PM
Amr_c63's Avatar
14 polar white E550
If this car had a true dual clutch or even a ZF transmission it would be just that much better. The Mct sucks in everyway but upshifts at WOT.
I don't understand how or why Mbenz would even choose such a crappy transmission in a car in this segment .
Old Sep 6, 2017 | 08:12 PM
Mikeki7's Avatar
CLS63, S55
Its just the nature of the MCT, it gets jerky but if you have it adapted correctly it can be smooth as butter. As the clutches wear your adaptation is going to get offset. The procedure should be in xentry/star and it guides you step by step as you are adapting the transmission. Its worth checking your transmission and engine mounts because that can cause jerkiness as well. Also the MCT benefits greatly from healthy transmission fluid. Software updates do help but there is a cutoff around 2014 for 2012-2013 models so you wont get the latest and greatest update, I believe in 2014 they updated the MCT mechanically to make it smoother therefore it gets its own updates. I didn't dig too deep into it and Im speaking from experience on my biturbo though I am pretty sure the 2012+ c63s have the same MCT.
Old Sep 7, 2017 | 04:05 AM
Celicasaur's Avatar
W212 - E63 AMG
Interesting.
Mine used to feel rubbish and harsh on downshifts until i had the solenoids replaced on my valvebody. It's perfect now.
Interesting point about the clutches though...I wonder if those have anything to do with the fact that my car doesn't do a burnout or spin the tyres from a stop
Old Sep 7, 2017 | 08:53 AM
cornerjunkie's Avatar
none
Originally Posted by Celicasaur
Interesting.
What was the cost to replace your solenoids?
Old Sep 7, 2017 | 10:56 AM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
This is the only thing I have seen that might help
https://europeanautosource.com/weist...u-upgrade.html
Old Sep 7, 2017 | 11:53 AM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Weistec doesn't offer it as a standalone upgrade anymore AFAIK - you have to get their rebuild now with it. I think I was one of the last to get it. Too bad because the shifts are vicious.
Old Sep 7, 2017 | 04:01 PM
BadCompany's Avatar
2014 C63 AMG Edition 507 coupe
latinskllz on here got it done too, but I'm not sure if he got it before they stopped offering it as a standalone. Not that it means anything since they could say it isn't offered anymore after purchase, but Vivid Racing is still selling the standalone upgrade from Weistec through their site.
Old Sep 7, 2017 | 06:31 PM
BLKROKT's Avatar
Right. Try to order it from those VR dooshes and see what they say. After they charge your credit card for it first.
Old Sep 7, 2017 | 07:30 PM
BadCompany's Avatar
Don't think I was suggesting that. A phone call to Weistec would be in order.
Old Sep 7, 2017 | 08:53 PM
go team's Avatar
2012 C63, GL63, 1989 300CE
MCT Adapt
Found this online for ease of access on how to reset MCT adaptability. I havent tried this out myself yet, however. Follow at your own discretion!
"Procedure Reset Transmission Adaptive Learning DIY
  1. Turn the key to position 2. You should see all the dash lights come on. Do NOT start the car. Position II: You should hear two clicks and all your dash lights should turn on. Do not start the engine.
  2. Press the gas pedal all the way. By pressing the accelerator pedal to the floor, you will activate the kick down switch. Keep the gas pedal pressed all the way to down.
  3. Wait. Continue to keep the gas pedal pressed for at least 10 seconds.
  4. Turn key to OFF, position 0. Don’t remove the key. Some models may need the key to be removed.
  5. Release the gas pedal.
  6. Wait 2 minutes. During this process, key is left in the ignition in the OFF position.
  7. Start the car and drive.
Once you perform this procedure the Engine Control Unit (ECU) and Transmission Control Unit (TCU) will work together to learn how you drive by monitoring your driving pattern. After you follow this programing method of the TCU / ECU drive the car for 15 min. Do not race the car, unless that’s how you plan on driving all the time. You should have a transmission that shifts smooth and normal. You may feel like you have a new transmission!"
Old Sep 7, 2017 | 09:41 PM
Celicasaur's Avatar
W212 - E63 AMG
It was something like £1100 or £1200 GBP.
Old Sep 8, 2017 | 08:34 AM
Schulminator's Avatar
2015 C63s Sedan
Just did the reset procedure noted above...huge difference in up/down shifting...much smoother
Old Sep 8, 2017 | 08:44 AM
NotABaller's Avatar
2012 C63, 2014 E550
awesome! I felt it was software related too.
Old Sep 8, 2017 | 02:07 PM
xEryx's Avatar
2019 E63s AMG
You can also permanently turn off the transmission learning/adaptation Worked on my C300 7G, should work on the C63. I am getting instant throttle response even during erratic acceleration, it comes at the cost of more fuel though.
Old Sep 8, 2017 | 02:55 PM
NotABaller's Avatar
2012 C63, 2014 E550
So what is the default mode for a unlearned/unadapted TCU? If resetting adaptations makes the car drive smoother, then I can only assume that it will default to granny shifting through the gears?
Old Sep 8, 2017 | 05:04 PM
Mikeki7's Avatar
CLS63, S55
It will default to granny shifting if you drive like a granny but the transmission is constantly learning so if you are driving aggressive while in granny mode, eventually it will switch to more aggressive shifting after a specific number of shifts. Just note that this little reset is not the same as the adaptation you do on a star diag. Star diag adaptation will tell to you to go to specific rpms in specific gears and reset the clutch engagement on the car. The tranny is always smooth when it shifts at high rpm, the jerkiness comes in when you apply light throttle or the transmission wants to shift downshift shift when driving regularly so the gas pedal reset is only a band aid.
Old Oct 1, 2017 | 11:55 PM
go team's Avatar
There will definitely be a car seat in mine. ETA 9 months 😊
Old Oct 7, 2017 | 12:45 AM
go team's Avatar
I have the Pirelli Sottozero's now and definitely going with Nokians studded this season when the current set is done.
Old Oct 7, 2017 | 12:54 AM
BLKROKT's Avatar
Thanks so much for your relevant contributions to this MCT thread
Old Oct 7, 2017 | 01:29 AM
go team's Avatar
Weird! I have no idea why it did that although i am on my phone!!
