message: "Full Service Could Not be Carried Out"
'09 C 63, got it with 1200 miles on the odometer in 2013 and now i have 10,600 miles. was CPO car so i have been treating it as if that was new date, per dealer, so this year was year FOUR. was due for B5 in April '17 but i drove it 100 miles since the previous April (2016) so i left it until it was convenient, which was this week.
performed services to spec, went through dash procedure like i have before, and the final message when i'm done is: "Full Service Could Not be Carried Out'".
i forget how many days it's "past due", but i am wondering if the mismatch in such low mileage vs. the time frame is causing this problem.
thanks for any suggestions.
someone in another post in here said they tried the process again the next day and it worked. that sounds very random and strange but i doubt they are lying.
it's funny that it says in service data or whatever "-110 days" but "+9700 miles", ha! that is accurate, though.
anyone else know why this happens if nobody screwed up?
Once you get hooked up to the diagnostic it'll run through and show everything is copacetic and you'll get the re-set you desire. To the best of my knowledge there is nothing that you yourself can do to push that through.
it does says -110 days but then +9700 miles since all told it appears i've driven 300 miles over the whole service period. i too have a feeling that is too far off from anything the computer would consider normal.
the independent i know doesn't have the ability to adjust that so i guess i will have to go to the dealer. sucks. i try to avoid them at all costs.
