V7 Pinging!? Anybody else’s?
#51
Yeah. I flashed it to stock and back like 3 times while on the dyno. Even the guy running the dyno thought it was weird how close the numbers were. I'm sure the tune is taking because I opted for the redline limit increase and I've hit it a few times
as well as the downshifts sound mean with the "blip function" and i can feel a slight (better) difference in throttle response. I was hoping to see at least 430 to the wheels but I'm pretty disappointed. He also put a monitor in the exhaust to measure afr but that didnt work out so well.
![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
#52
i also have access to hptuners and vbox to do testing, data logging and can buy dyno time but when I asked if this would help to create a better more specific tune I was told no it's as good as it gets as there's not much to adjust ???
Also that the afr range at wide open throttle was between 12.2-13.4 surely that's quite wide and should be possible to tune into more ?
i like my v5 it works well and the car runs great I don't want to change and not be able to revert back which is why I haven't put the v7 on and not sure if I will
#53
that's what I was told by when I asked
#54
You can either run it lean with high timing but with increased octane, or you can run it a bit richer and sacrifice 4-5hp in order to gain ~10+hp.
#55
Where can we download the Tuxedo AMG skin for Dash Command?
#56
a unicorn tuned p30 e63
i am getting a new one made, ill post up then. glad you like it!
