Fail intake manifold swirl flaps M156 2007 ML63
when i rev the car there is a really loud knock from within the intake manifold so we took it out to make sure nothing had broken loose and found the actuating mechanism that opens and closes the swirl flaps and the swirl flaps themselves have quote a bit of play and wear.
are these replaceable or do i need a whole new manifold? we were also really surprised to find quite a bit of oil not only inside the manifold but resting on the block where the manifold usually sits.
any help would be great guys. Thanks
my issues got worse today. we put the bad manifold back on after a good clean and after running the car its throwing codes related to rhs exhaust cam hall sensor which i think is also the position sensor, fault for the fuel pressure sensor that sits on the fuel rail and missfiring on cyl 1, 2 and 3. **** just got real.
so the guys are pulling it back apart tomorrow to recheck their work after doing the cam adjuster fix (which works a treat btw) they are suspected a possible break in the wiring loom because cam sensors were swapped from left to right and the error is still on the right.
i personally think they've put something in incorrectly and suspect the 3 metal rings that on the gear between the cam adjusters and the solenoid has slipped and come out of the grooves.
the joys of owning an m156.
i have a P31 (dark gray) intake manifold off my m156 if you are interested. Located in the U.S., shipping may not be cheap but let me know. Only 29k miles on it, went with a supercharger. Pm me if so. You will just need to swap your throttle bodies and accessories over.
