C63 AMG (W204) 2008 - 2015
lifters replaced but still hear tapping
Old Dec 20, 2019 | 02:19 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
the noise in the video is that of a cam adjuster. all brands and engines that have adjustable cam gears sound the same when they get some miles on them. doesn't mean they aren't functioning correctly just that there is some miles and usage on them. when they get loud or not sweeping correctly thus throwing a code is when they need replacing.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Dec 20, 2019 | 02:40 PM
Viktori's Avatar
C63 AMG W204
here is photo from internet, by which part of cam adjuster it make that sound? on engine ON they full of oil and it's oil pressure not give them to make any noise, if there is no oil pressure, engine become noise like a hell and no power etc
Old Dec 20, 2019 | 04:00 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
I think it’s the round metal part that makes the noise
Old Dec 20, 2019 | 04:02 PM
Viktori's Avatar
C63 AMG W204
it's touching with crank sensors, if there is anything wrong even in normal wide values it can be detect by star diagnosis but there is nothing
Old Dec 20, 2019 | 04:03 PM
Viktori's Avatar
C63 AMG W204
main and the most valueble question, why it's comming only on hot engine, nothing on cold, absolutely
Old Dec 21, 2019 | 12:07 AM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Do the replacement lifters come with a larger hole at the top?
Old Dec 21, 2019 | 10:48 AM
  #32
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
You mean the oil gallery on the side? There are no holes on the top of the lifter.
Tasos uploaded a couple decent vids recently.
Old Dec 21, 2019 | 12:16 PM
  #33
Adi-Benz's Avatar
Ah, thought they might be similar to some other lifters, like these:
Solution to the tapping was increasing the hole size so that more oil could get in (pictured with larger holes). These are much different though.
Old Dec 21, 2019 | 01:46 PM
  #34
BLKROKT's Avatar
The lifters have holes on the sides. The Tasos video from the other day showed that soaking them in oil does nothing. You have to pump them full of oil right before installing.
Old Dec 21, 2019 | 01:58 PM
  #35
Adi-Benz's Avatar
I think it's somewhat of a bad design in general then (I'll be honest haven't read most of the lifter threads) I wonder if larger holes in the sides will help then.
Old Dec 21, 2019 | 02:47 PM
  #36
Viktori's Avatar
C63 AMG W204
Here is my videos
1st: engine 65 degreese celsium, no sound
https://www.youtube.com/watch?v=d5a1DzbSFlI
2nd: engine 70 degreese lot of sound
I asked benz dealer about it, they said only oppening will help to determined, no guessing
Old Dec 21, 2019 | 07:33 PM
  #37
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Originally Posted by Viktori
Here is my videos
That's just the CAs. They start to get noisy over time, don't worry about it.
Old Dec 22, 2019 | 02:30 AM
  #38
Viktori's Avatar
C63 AMG W204
Lightbulb
what is CA? cam adjusters? there is not big deal in that sound, but if I will want to sell car, it will be hard with that noise
Old Dec 22, 2019 | 08:38 AM
  #39
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
It's a normal noise. Spend 2-3k to replace all the CAs (Cam Adjusters) when you sell if you think it will hurt resale.
Old Dec 22, 2019 | 08:53 AM
  #40
Viktori's Avatar
C63 AMG W204
I can spent 800$ for 4 plates, or 200$ for plates from factory turner, but noise not from plates, there is no rattles on cold, what part of ca cause that noise?
Old Sep 11, 2020 | 06:34 AM
  #41
jpman's Avatar
2009 E63
Here is my videos
https://www.youtube.com/watch?v=7Ny2V0mDGWc
Now that I read this, funny. My 09e63 has this same behavior. No noise when cold, but has this same noise when warm. Viktori, did you ever figure anything out with this?
Old Sep 11, 2020 | 07:09 AM
  #42
Viktori's Avatar
C63 AMG W204
nope, it's still there, soon I will replace lifters to black series one and will report if it fix problem, also I have inno lifters intalled, which is not mercedes marked
Old Sep 11, 2020 | 08:52 AM
  #43
jpman's Avatar
2009 E63
Hmm... don’t know if it’s really related to the lifter. Have you thought about the cam adjuster not locking completely? There is a video from Tasos that has him put a wrench to it to check. You can tell right away.
Old Sep 11, 2020 | 12:04 PM
  #44
jpman's Avatar
2009 E63
video for reference
Old Sep 11, 2020 | 05:50 PM
  #45
go team's Avatar
2012 C63, GL63, 1989 300CE
Adjusters.
Old Sep 11, 2020 | 07:27 PM
  #46
Cwagon's Avatar
2013 W204 C63 AMG P31 Estate wagon
From your second video it sounds like mine did before I replaced all my lifters (with Inno brand, FCP euro) and did the Tasos pin flip om my CA base plates.
My CA noise was louder than yours but I also had lifter ticking around the middle of the left bank.
All my plates have signs of wear but the pin flip must have worked as they are now quiet 14 months and 7,000klm on.
Used Liqui Moly 5w40 and Ceratec after the change was done and my last oil change used same oil but with MOS2 added.
No ticking so far.
Btw people have reported that they replaced all 4 CA's at stealers and still had the ticking.
Old Sep 19, 2020 | 09:38 AM
  #47
Viktori's Avatar
C63 AMG W204
Angry
problem not fixed and it become even worst
Old Sep 19, 2020 | 05:29 PM
  #48
Heaven7's Avatar
'10 C63 AMG
I hear a lot of reports about ticking lifters and noisy cam adjusters here. My 2010 C63 doesnt have any of that at 41k miles. Currently running Motul 8100 5w40.
Aside from the noisy, is there any chance of catastrophic failure or engine damage associated with the noisy lifters and cams? If its just the noise, it sucks but it's livable.
My fear is that this could end up being an expensive repair bill, like broken head bolts.
Old Sep 25, 2020 | 04:17 PM
  #49
Viktori's Avatar
C63 AMG W204
ok, problem found and fixed, thats crazy, but it's temp oil sensor beru st011, I have a problem with fuel pressure CHECK ENGINE light on, it's like problem which nobody can fix, but on one forum I found info about temp oil sensor replacement will help,
and it fixed also problem with slapping somehow. Also it's not lifters, it's chain slapping.
Old Oct 7, 2020 | 12:13 AM
  #50
nm4's Avatar
nm4
911,350Z,E63
Viktori, how did you diagnose the chain slapping and have you identified a fix?
NM
