C63 AMG (W204) 2008 - 2015
Header Install Help
Old 02-02-2019, 01:53 PM
  #51
c63panda's Avatar
2012 C63 Coupe
After collecting dust for almost a year, you've inspired me. Installing in a couple months
Old 02-02-2019, 02:39 PM
  #52
SactownP31's Avatar
C63 p31 coupe, Clk550 cab, M3 coupe, LS430, 750LI
Yeah it's a tough job but it can be done. Having the right tools and small hands will be key, I had neither. Also after install a few hundred miles later you'll have to adjust things that may start to rub. That job was tough and after that I pretty much work on any other mechanical task that comes up. If you can install headers on a c63 on a garage floor with jack stands after 8-12 hrs of intense, dangerous, physical tree work, you can pretty much handle anything else. Good luck and be patient.
Old 02-02-2019, 11:31 PM
  #53
Fhast's Avatar
2009 C63 AMG
My dude hook me up with intel on how to get around SMOG. Congrats on the install btw, did mine with my bro about a month ago. I enjoy every morning hearing her bark
Old 02-03-2019, 12:14 AM
  #54
SactownP31's Avatar
Yeah its savage in the mornings. It still scares people when I hit the gas or downshift. As far as smog, mines due in june. But I know a guy who is a "smog specialist". I left my rear o2's on so mine is going to be a little easier, just has to pretend he didn't see the lth. $100 some modelos and some chicharrones or queso flavored ruffles and its a done deal.
Old 02-03-2019, 01:18 AM
  #55
Fhast's Avatar
2009 C63 AMG
LMAO
I left my rears too. If I need some help come time smog you think your bud would help out?
Old 02-03-2019, 01:50 AM
  #56
SactownP31's Avatar
Originally Posted by Fhast
LMAO
I dont see why not, he's in the sac area, where you at?
Old 02-03-2019, 03:20 AM
  #57
Fhast's Avatar
2009 C63 AMG
👍. Im located in the east bay in Antioch. Not too far from Sac
Old 02-04-2019, 07:20 PM
  #58
c63panda's Avatar
2012 C63 Coupe
white 507 sedan?
Old 02-05-2019, 11:50 AM
  #59
Fhast's Avatar
2009 C63 AMG
Originally Posted by c63panda
white 507 sedan?
No I have a Black Chrome sedan base model. You are around this area too?
Old 02-06-2019, 03:56 PM
  #60
c63panda's Avatar
2012 C63 Coupe
bwood
Old 02-10-2019, 11:13 AM
  #61
c63panda's Avatar
2012 C63 Coupe
Hey could you guys post a side pic under the car? I found one pic of coated arh that seem to drop pretty low but can't find it anymore. I'm trying to figure out how low/clearance i would have before I install them
Old 02-12-2019, 06:24 PM
  #62
c63panda's Avatar
2012 C63 Coupe
"CALLING ALL HATERS"... You may begin
Old 02-13-2019, 02:42 AM
  #63
Fhast's Avatar
2009 C63 AMG
Old 02-23-2019, 03:00 PM
  #64
c63panda's Avatar
2012 C63 Coupe
Removal was pretty straight forward. I was able to remove all top nuts from the top. Pulling driver side coils helped. Closed end wrench with pivoting head definitely helped with bottom nuts. I figured out that you're able to reach a few nuts with extensions and a regular ratchet if you look hard enough. Definitely need to remove fire shield around column to take stock header out. Removal took 4 hours without dropping the rack. Install time?.... 3-4 weeks lol. Found out I need new mounts and that's how long it'll be for the next run of ECE mounts
Old 02-23-2019, 03:44 PM
  #65
BLKROKT's Avatar
Received 2,836 Likes on 1,674 Posts
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Oh. You don’t know. Removal of the OEM logs is the fast part. The install of the new much larger headers is when the fun really starts. Good luck.
Old 02-23-2019, 07:36 PM
  #66
c63panda's Avatar
2012 C63 Coupe
Lol i'm gon find out...
Old 03-08-2019, 09:03 PM
  #67
c63panda's Avatar
2012 C63 Coupe
I found out... Driver side was a breeze. Passenger side was a mf'r. Passenger side went in and out 3 times! I kept dropping the top back nut and each time it went in between the pipes near the collector. Not 100 percent yet, the o2 extensions were short.
Old 03-09-2019, 03:48 PM
  #68
MTV10's Avatar
E55 AMG & C63 AMG
I literally just stared at that pic for 10 mins.... so sexy
Old 03-09-2019, 05:16 PM
  #69
c63panda's Avatar
2012 C63 Coupe
I put in the ece mounts without heatshields, felt bad, then did them over with the headers in smh lol. This is how tight it is even after bending and shaping the shields with arh.
Passenger side with about a mm gap. No test drive yet, hoping i don't get a rattle
Driver side should be good
Clearance from steering shaft
Old 03-09-2019, 06:03 PM
  #70
SactownP31's Avatar
How's your clearance from cross bar in the back? It also seems like my tail pipes stick out more and rub on my ebay defuser.
Old 03-09-2019, 06:29 PM
  #71
c63panda's Avatar
2012 C63 Coupe
Half to one inch clearance, no washers
Old 03-09-2019, 07:49 PM
  #72
Fhast's Avatar
2009 C63 AMG
Mine stick out more too
Old 03-09-2019, 07:56 PM
  #73
Fhast's Avatar
2009 C63 AMG
We had to lift the engine to do the passenger side. Id say that was longest part of the whole install. Congrats on the install though I know that feeling of when finished!
Old 03-09-2019, 08:02 PM
  #74
c63panda's Avatar
2012 C63 Coupe
Sad, still haven't got to start it yet. Waiting on longer o2 extensions and intake spacers
Old 03-09-2019, 10:39 PM
  #75
SactownP31's Avatar
Did you undo the stock ones and run them up the middle? If you don't remove them from the brackets they won't reach. Which spacers you going to run?
Quick Reply: Header Install Help
