C63 AMG (W204) 2008 - 2015
Header Install Help
Old Mar 9, 2019 | 11:24 PM
  #76
c63panda's Avatar
2012 C63 Coupe
Originally Posted by SactownP31
Did you undo the stock ones and run them up the middle? If you don't remove them from the brackets they won't reach. Which spacers you going to run?
Installed the x and cats first. Took the hangers off the stock tailpipes then connected the crossmember section. Connected stock to new, put back on the hangers, tightened clamps.
Not actual intake spacers, don't think I'd ever. I'm waiting on supposed phenolic gaskets.
Old Mar 10, 2019 | 12:18 AM
  #77
SactownP31's Avatar
C63 p31 coupe, Clk550 cab, M3 coupe, LS430, 750LI
Was talking about the wires.
Old Mar 10, 2019 | 12:55 AM
  #78
c63panda's Avatar
2012 C63 Coupe
Ahh, they reach but dont like the look so I ordered 24" extensions. This way (hopefully) they can stay on the original bracket and stay outta site. Think I only needed the passenger side longer but might do both cause the driver side had zero play
Old Mar 10, 2019 | 10:10 PM
  #79
c63panda's Avatar
2012 C63 Coupe
24" extensions are perfect
Old Jan 5, 2026 | 11:22 AM
  #80
kev.c63's Avatar
2012 Mercedes Benz C63 AMG
Engine mount ARH Rubbing
Hi, I am having the same rubbing issue. How did you bend the engine mount heat shield. It’s made of a a spring like metal so every time I try to bend it with a pry bar it tends to spring back to it’s natural shape. I am having the problem on the passenger side.
Here's some pics of the rubbing and quick fixes.
Passenger side rub.
After I bent some shyt. Got about a 1/4 inch of clearance. All you need.
Driver side rub fixed, no pre rub pic.
Old Jan 5, 2026 | 12:06 PM
  #81
c63panda's Avatar
2012 C63 Coupe
So long ago, got a g now. I think I had to remove the shield completely to reshape
Old Jan 6, 2026 | 12:43 AM
  #82
Phil_T's Avatar
C63 AMG Saloon
You will have to take it off put it on a bench and hammer it to shape, using a pry bar will do nothing.
