tire / wheel fitment
will these fit a 2013 stock (p30) c63 with no issues?
front 19x8.5 ET 38 245/35
rear 19x9.5 ET 56 265/35
I'm guessing they are off a w205 c63so I'm thinking probably not...
I
I
the front will be pretty flush but you can go as aggressive as 35 et up front with no rubbing. The rear will be a bit tucked similar to how stock wheel looks in rear but not bad. For reference I have a 9.5 rear wheel with 265 tire et 47 and it's flush aggressive no rubbing.
kavik (01-27-2018)
Ok I am about to buy these wheels for my 2013 c63 w204. ... the guy is holding them for me, but I am a little confused.... they look like c63 w205 edition 1 wheels, but the edition 1 wheels are supposed to be 19 front / 20 rear, and the seller says these are all 19".... which is good for me to fit my W204, but I want to make sure theyre not replicas. Or were these also offered in the 19 all around?? The seller seems reputable..
FRONT 19X8.5 ET38
REAR 19X9.5 ET36
TIRES: FRT: 245/35R19 MICHELIN SUPER SPORT
REAR 265/35 R 19
FRONT 19X8.5 ET38
REAR 19X9.5 ET36
REAR 265/35 R 19
So I have been looking at tire size comparison/ratios and it seems normally the fronts tires on C63 are about .5" taller than the rears...
Im not sure the 265/35s will work, wont the rear tires be .5" higher now than the front ( according to the calculator) ? Will I need to switch rears to 265/30's to get the car level (not rear high) and the speedo closer?
Yes 265/30-19 would be the correct size for a W204 C63 on the rear. One width size up from an OEM 255/30-19.
The rear tires on those wheels are too tall.
