get real volks if you like that look - not knock-offs..... I actually have the Te37 PCD's on my landcruiser - damn nice rims for a 20" setup and only 23lbs !
that said - lot's of better options.... at least IMHO
Not a fan then... I have a c63 Estate and think they will suit the car. My other alternative was the quantum44 s1’s in bronze.
Well you have a Mercedes, not a Nissan, VW, or Ford Focus. The Bola B1's do not suit/match the car. Quantum44 s1 would look a whole lot better. As far as fitment, most sites have some guide of what fits our cars.
Now it’s a whole other argument about knockoffs vs real thing etc. But you’re getting the wrong size for the rear at least. 8.5” is really going to limit the rear tire width which is where you need it most. But if you’re only concerned with looks, and like it then whatever I guess. I don’t know anything about offsets you’ll have to measure, plus make sure they’ll clear the calipers. Maybe you can use the info from the above Volk post as reference.
Yes it will fit. Guys run et45 on 9.5 rims on the rear. this is an 8.5, as long as it's correct bolt pattern you shouldn't have an issue. I wouldn't run an 8.5 in the rear though. Those rims don't look like they should be on a Benz just my opinion.
The Bola site includes a fitment check - probably a good place for you to have started. It very clearly says yes to 18" and NO to 19"
those fitment guides are not always correct. 19s fit fine. If I listened to these fitment guides I wouldn't have my 17 inch drag wheels. It said those wouldn't fit either, but they fit perfect.
