Is my engine affected in the head bolt saga? Help with engine serial from Vin/chassis
Subscribe
Mar 10, 2018 | 12:50 AM
Hi there everyone
New here. I have read a lot recently on head bolt failure and corrosion on the M156 engines, I have a 2011 C63 amg and I know there was a switch during 2011 at some point. I am unsure whether vins are universal all across the world, I am in New Zealand. I am posting my vin and chassis in the hope that someone can tell me if my engine is in the affected range or if it is outside the head bolt issue range.
Thanks everyone
2011 C63 AMG
VIN: WDD2040772A608246
Chassis: WDD2040772A608246
Reply 0
Mar 10, 2018 | 06:56 AM
You can't tell by your VIN specifically, you need your engine serial number, so either find that on the engine and compare to the range here https://mbworld.org/forums/c63-amg-w...rly-2011s.html
Or post your VIN in the vin decode thread to get your datacard that will give you your engine serial to compare https://mbworld.org/forums/c63-amg-w...in-decode.html
Reply 0
Mar 10, 2018 | 12:55 PM
I’m pretty sure the other way is to look at your valve covers. If they’re the black/plastic ones, then you have the revised engine.
Reply 0
Mar 10, 2018 | 04:08 PM
Looks like he got his answer in the headbolt thread, he is good!
Reply 0
Oct 28, 2021 | 11:33 PM
Hi everyone I am looking at buying this c63 amg in australia. He is after 52k aud but I’m thinking 47k aud. 80,xxx kms.
IS THIS HEAD BOLT ISSUE AFFECTED PART OF THE 2006-2010 issue????????
Reply 0
Oct 29, 2021 | 03:35 AM
To NathanC63 and Dannyboi:
Try posting your question in this specific thread: https://mbworld.org/forums/c63-amg-w...rly-2011s.html
Reply 0
Subscribe
Currently Active Users (1)
