C63 AMG (W204) 2008 - 2015
LSD
Old Mar 20, 2018 | 04:09 PM
spudsAMG's Avatar
AMG C63
LSD
Hi
How can I find out if my C63 AMG as a limited slip differential?
Old Mar 20, 2018 | 04:33 PM
Amr_c63's Avatar
14 polar white E550
Originally Posted by spudsAMG
Hi
You could run the vin # and see if you have the option code ( 471 ) or lift the car up in neutral and spin the tires by hand and if you both rotate the same way then you got it .
Old Mar 20, 2018 | 05:45 PM
Infiniti's Avatar
a unicorn tuned p30 e63
Hi
do a burn out in times square, have someone film it and we will let you know
Old Mar 20, 2018 | 05:53 PM
gtracer's Avatar
'13 C63 & AP2 S2000
1. Turn ESP off.
2. Manual mode.
3. Drive up to 3000rpm in 1st gear.
4. Yank the wheel left or right (your choice).
5. Mash the gas and shift 2nd gear.
If you spin out and lose control, you have LSD.
If you dont lose control and just turn circles with inside wheel in smoke, you dont have LSD.
Old Mar 20, 2018 | 06:20 PM
AMG3.2's Avatar
C63 AMG, P30
Originally Posted by gtracer
1. Turn ESP off.
2. Manual mode.
Two very solid options
Old Mar 20, 2018 | 06:38 PM
skratch77's Avatar
2005 E55
Just run the vin in the vin thread
Old Mar 20, 2018 | 07:42 PM
gmore's Avatar
'10 C63 P30
Hi
vin search here...
http://carinfo.kiev.ua/cars/vin/mercedes/vin_check
look for listed option #471 mechanical locking differential
Old Mar 20, 2018 | 09:07 PM
ItalianJoe1's Avatar
2003 CL 600
Lift the car and spin the back tires by hand. If the other wheel turns the same direction, LSD. If it goes opposite, open diff.
Old Mar 21, 2018 | 02:02 PM
Savage-wp's Avatar
2014 Mercedes C63 AMG 507 Edition
Posting the VIN number in the correct thread is the easiest.
Doing a monster burnout, and looking to see if you left 1 or 2 lines is the most fun way.
Old Mar 21, 2018 | 04:41 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
How is a VIN going to tell you if one was installed after the fact?
If I run my VIN it will say I don't have one when I do...
Old Mar 21, 2018 | 05:00 PM
Savage-wp's Avatar
Good point, the VIN will only tell him if his car came from the factory with the LSD.
A quick burnout is the quickest way to tell then.
Old Mar 21, 2018 | 06:52 PM
2003 CL 600
My open diff CL600 will lay two black stripes the length of a parking lot. Not a conclusive test.
Old Mar 21, 2018 | 08:05 PM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
Agreed, my BMW will also with some electronic magic but you can tell it is different, but if you jack it up and turn the wheel the wheels wlil turn in opposite directions showing it is really an open diff - that is the most conclusive test, get it off the ground and turn one wheel and see which way the other goes.
