Interested in an Used AMG (New Member)
This is my first post on MBWorld and I wanted to ask a question that may have asked many times in the past. I'm currently an Audi A4 owner and have been driving it for more than 8 years. I want more power as well as AWD with reliability.
What year/model of AMG that is most reliable and fast? I love the V8 sound of an AMG. But I know C63 is rear wheel drive which it may not be the best to drive in snow.
I fell in love with the power and especially exhaust note of an AMG 63s. The S4 (a V6) couldn't produce that sound. There is no comparison between the two cars. The V8 sound in the AMG 63 just excites me. Audi RS cars are hard to find and the latest RS4 was build 2007 which is over 10 years old. The current new RS3 is just too small for me.
I'm not interested in BMW cuz they are overpriced and the interior is way out dated.
My currently A4 B8 is worth less than $10k, so it doesn't make sense to dump more money into the car.
I wanted to get some feedback from the peeps on this forum to help me do the research on an AMG. Any model year car that has the least issues or repairs?
I'd target a 2011+ C63 or E63 depending on you size needs.... the C63 4dr has limited rear room but otherwise is more tossable, where the e63 is a great cruiser...
Cheers and happy hunting. !
I found a 2009 AMG c63 with 97k miles on it. Is the 2009 model year good?
Thanks for the helpful info. The repair bill is high on a 2012 or older C63?
My last car was a 2011 S4 and I ran snows and it was better, but for all I drive in actual snow it isn't an issue with the c63
I've owned a C63 for 5 years, not that good in snow unless you have snow tires, then it's marginal. An A4 with snow tires, will handle better then a C63 with the same setup. But if your looking for AWD then would suggest getting a C63S. It has plenty of grunt, with the benefit of AWD. The best of both worlds.
In terms of maintenance, Audi A4 is not cheap to maintain. My water pump broke at 30k miles and I spent $1k to replace it. The transmission maintenance service cost range from $500-$1000 depend on labor cost. The timing chain tensioner issue on my A4 cost at least $1000 to fix. So I would walk away from an used C63 AMG if you think A4 maintenance cost listed are way cheaper than a C63 AMG.
I was looking at used C63 AMG on Ebay. A 2011 C63 AMG with 78k miles cost $26k. Do you think the repair bill will be high on a close to 10 years old AMG c63 with close to 100k miles on it. I know C63 AMG engine is a bullet proof, but I'm not sure about the transmission and other weak points in the car.
My budget is under $30k.
I've owned a C63 for 5 years, not that good in snow unless you have snow tires, then it's marginal. An A4 with snow tires, will handle better then a C63 with the same setup. But if your looking for AWD then would suggest getting a C63S. It has plenty of grunt, with the benefit of AWD. The best of both worlds.Last edited by AMGC; Apr 4, 2018 at 08:43 AM.
That's what I thought.
I have done some search online for used C63. There are only a few on the market. I guess no many people own a C63 compare to the number of Audi A4 owners.
Have you driven a C63 yet ? if not that's really the initial thing you need to do....... utterly different feel than a Quattro car - and very different interior etc...
I know C63 is tail happy like a Mustang or any high power RWD car.
Does C63 eat motor oil? My A4 burns a qt of oil every 2500 miles.
The oil consumption comes down to the oil you're using - for whatever reason, Liqui Moly hasn't burned a drop in my car, but Mobile 1 would.
The engines eat oil, make noise, cost a bunch of money to modify, and running costs are fairly steep, but the overall experience is worth it. The cars are bulletproof and a blast to drive.
Find a late 2011+, which has revised headbolts, and the MCT. Both make your life easier, and cheaper in the long run if you choose to modify the car.
I'm new to MB. But I'm not new to German cars. It is expensive to mod my A4 as well. But I think I won't be doing much mods on an AMG if I have one. It is already fast.
I may need to put a pair of wider tires in the back to improve traction. How much oil do you need to add for every 2500 miles? I found a thread on oil consumption on C63. The OP stated that he had to put 1.5 qt of oil for 1000 miles. In my 2010 A4 owner's manual, Audi claim the car consumes a qt of oil every 600 miles is normal. Ha!
Also, I wanted to add: The C63 engines are not bulletproof. Prior to 2011 (and even in some early 2011 cars) there is a well documented head bolt issue. I would highly recommend doing a search on that topic and looking 2011 +.
