Question of replacing the engine oil
And one more question, if the oil in the engine is small level - will the error on the dashboard light up?
Thank you in advance!
If the oil level is low the sensor should turn on the warning in the dashboard but sensors can fail so there is no guarantee.
The indicator on the dashboard did not light up.
I poured another 1.5 liters. The level was the maximum on a cold engine.
I started the engine. There was a knock of the lifters. He disappeared only after the temperature had risen to 50 degrees
PS - Tell me, something that could break in the engine if I was driving with this level of oil. as in the picture? The indicator on the dashboard did not light up. Why was knocking of the lifters?
You should not hurt anything driving with that level of oil in the engine
Why could ticking lifters on the next day after oil change? I do not understand.
Oil fresh. Before that, the car stay a month in garage , but I started engine and warmed it up several times.
Yesterday and today started the engine - no knocking.
Don't worry unless it remains there. These engines seem to do these things at times,
