C63 AMG (W204) 2008 - 2015
Rear Wheel Size
Old Apr 7, 2018 | 07:45 PM
corsair944's Avatar
2015 C63 Coupe
Rear Wheel Size
Hi everyone,
Just got my new (to me) 2015 C63 coupe home.
Is anyone running 19 X 9.5 ET 45 on the rear of their car?
I found a set of Brabus and want to make sure that 9MM offset difference will work
I posted in the wheel forum and no replies
Thanks Everyone
Old Apr 8, 2018 | 06:38 AM
Rick X Joaquim's Avatar
C63
255/30 no problem
265/30 edge
275/30 probably will rub
Old Apr 8, 2018 | 07:03 AM
Texas E63's Avatar
Built 2008 G55 & one big 80 Series LandCruiser !
I'm running a forgestar 18x9.5 et 48 w/ 275's on stock suspension with plenty of room....
Old Apr 8, 2018 | 05:21 PM
C63
I have 255 on 9” with 45 offset and i measure the very top of tire to inner fender. There is probably 10mm max but I would not strech that far but the side wall are definitely further out but these are 35 on 18 so there is plenty of vertical clearance. 45 offset wit 265 is probably the max you want to go before rubbing. Keep in mind that a 255 30 series will leave u slightly less vertical clearance ove 265 30 series . Same goes to 35 for 18”
those who run 275 are usually running a higher offset to compesante the tire width.
48 offset on 275 on 35 18 and not rub you are lucky. Dont let those gaps deceive because doesn’t run stationary. It will bounce up and down.
Old Apr 8, 2018 | 09:16 PM
Verno's Avatar
12' C63 P31,15' Maserati MC Sport
What spoiler is that o.O? Thnx
Old Apr 8, 2018 | 09:20 PM
AMGonFire's Avatar
2012 c63 AMG, 2011 GLK 350, 2019 GLS 450
Originally Posted by Rick X Joaquim
255/30 no problem
265/30 edge
this is your answer for an et 45. 265 max my opinion if you don’t want to rub
