C63 AMG (W204) 2008 - 2015
Fender rolling and pulling
Old Apr 13, 2018 | 05:11 PM
Rick X Joaquim's Avatar
C63
seems like not alot of people have rolled and pull their fenders. I think this could a great mod for those who don’t want the trouble of fender flares and also be able to run wider tires.
by pulling 10mm out we could run wider tires and i think this could a subtle but different look from the rear view.
what yu guys think?
Old Apr 13, 2018 | 05:30 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
I love mine. Have 295’s back there now with the car slammed and could get a 305 back there with a less aggressive stance. Looks factory.
It’s not an easy job though especially getting the shape to match both sides.
Old Apr 13, 2018 | 10:20 PM
Celicasaur's Avatar
W212 - E63 AMG
A friend of mine here has it and it looks similar to the job on BLKs car. I like it...but don't pull it out too much and loose the flat, factory rim...the pic above is about perfect.
Old Apr 14, 2018 | 03:51 PM
C63
I agree. It look really nice and subtle. Makes people scratching their head why it look different.
Old Apr 15, 2018 | 05:00 PM
iShootYou's Avatar
2019 e63S, 2017 Audi R8 Twin Turbo
Are yours rolled or do you have the hms kit?
Old Apr 15, 2018 | 05:28 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
It's rolled an pulled.
The pics are an example of what rolled and pulled looks like in this rolled and pulled thread.
He also loves his rolled and pulled fenders.
Old Apr 16, 2018 | 04:37 PM
Kriston's Avatar
C63 AMG
These 2 are pulled and flared. I tuck a 295 as well. A 305 is definitely doable if im not slammed.
Old Apr 16, 2018 | 05:00 PM
Texas E63's Avatar
Built 2008 G55 & one big 80 Series LandCruiser !
I've got a solid shop that I trust locally and would love to get a 295 on her especially given the mods I've got sitting in the garage ...... what's ballpark cost to get a shop to pull them ? any paint work needed ( magno makes that less appealing....)
Thanks !
Old Apr 16, 2018 | 05:27 PM
Kriston's Avatar
C63 AMG
Paint work definitely needed
Old Apr 16, 2018 | 10:00 PM
BLKROKT's Avatar
100% paintwork is needed. My car was also stripped down to bare metal like Kriston’s. You’ll also need the BS fender liner and trim it to fit.
I initially had had the fender lip just rolled temporarily so I could stuff a 285 back there for a trackday, and the entire edge chipped and cracked.
Old Apr 21, 2022 | 07:26 PM
ramony98's Avatar
w204 C63 p31 facelift
Hello
I want some more detailed informations about pull or roll the rear fenders on the w204.
Maybe you help me with your experiences around the topic.
I have 19" BBS Le mans rims and the wheel stands out about 1 cm from the rear fender at the top.
It bothers me that it is not flush with the body at the top of the fender.
Do you guys think I can just go to a professional bodyshop and get this 1cm from the fender?
Rear:
  • BBS Le mans HA 9.5 x 19" ET 32
  • Yokohama Advan Sport (V105S) 245/35 ZR19 (93Y)
  • lowered with Suspension "KW Clubsport V3"
@Kriston You posted a photo of the silver W204 sedan with same BBS Le mans rims. Do you have any more detailed photos of the pulled fender? I would be interested in the dimensions of your BBS rims. Especially the offset and exact size.
Old Apr 21, 2022 | 08:41 PM
lo-fi's Avatar
2009 C63 AMG
Originally Posted by ramony98
Rear:
I can't help with your question but I have a couple questions of my own. What are your specs for the front? Any rubbing on front or rear? I'm asking because I'm considering buying some LMs myself.
Old Apr 22, 2022 | 12:39 AM
N I L's Avatar
C63
Hello
Rear:
There's always a risk that the paint will crack/chip that comes with rolling/pulling territory
Having sported rear 30 offsets w/o wide fenders it's only a matter of time before you scrape/clip the fender w/o raising suspension
If you don't want to molest the original fenders you could always do one of the two
Depending on structure/material to work with including brake caliper clearance you could have an experienced machinist or reputable wheel repair shop take off 3-5mm w/o compromising drivability/vibration, etc to increase offset.
Since you're running a considerably low stretched profile rear tire you may be able to get away with rear camber arms at the expense of additional camber wear w/o rubbing
Can only speculate but front's appear to be +30-32 offsets, would be super cautious when clocking in/out of entrances/exits. Depending how low you are it could potentially clip compromising original fender lines
Old Apr 22, 2022 | 02:57 PM
Kriston's Avatar
C63 AMG
Great looking set! LM's hold a special place in my heart.
My old setup was 20 x 9.5 rear with a similar offset to you 33. Front was 20x8x5 ET 35. I pulled the fender about an inch on either side with this setup. However since this i have moved on to an actual wide body setup. Now running 20 x 12 Rears et 32 on 305's. 325 wide rears fit on my current setup. But thats with a wide body.
Hello
Rear:
Old Apr 23, 2022 | 03:08 PM
ramony98's Avatar
Front: 8.5 x 19" ET32
Rear: 9.5 x 19" ET32
No I dont have rubbing on front. Only on the rear. Maybe another offset at the rear would have better fitting but Im speaking as an beginner in this tuning things
Old Apr 23, 2022 | 03:16 PM
ramony98's Avatar
@Kriston thanks for you reply. For me it would be better to pull the fender about 1inch, because I don't really like a wide body at the back of the w204.
Please share some detailed photos off your silver 6.2L Jam Juice
I need to know how it looks with the pulled rear fender
Old Apr 23, 2022 | 03:31 PM
ramony98's Avatar
@lo-fi
Old Apr 23, 2022 | 07:29 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
You can pull the front quite a bit. This is with a 19x9.5 +27 with a 265/30-19 Cup2
