What to tell alignment guy
So now I put on H&R springs, have new wheels and tires coming and need to know what to tell the guy that is going do do the alignment. I know the camber needs to be straightened out to keep the inside wear to a minimum but everything I'm reading says there is no camber adjustment, or do I have terrible reading comprehension.What are my options since I don't want to eat through those PS4s like I did my last set? What do I tell the alignment guy since the last guy didn't get what I was trying to tell him?
I know I have probably disappointed the forum gods on my search failures so I will take my punishment...lolol
K-mac makes a set https://k-mac.com/
The previous owners how coilovers which I'm sure he had it aligned for those. He replaced those with factory springs to original ride height before I got it so I assume no alignment after. The wear even happened after I had aligned to Merc specs. Nothing appeared bent when I was just under there putting my H&Rs on but I'm not eliminating that possiblity. This is what it looks like now which really isn't that much cambered in than before. I'll see what the alignment dude can do when I get my new wheels but if no better I'll get the Kmac stuff. Would there be any benefit to taking it to a Merc dealer for alignment?
Only Toe is adjustable. Incorrect Toe will kill your tires more than camber. There is no other adjustability from factory. The lower you go, the more camber you get. I was at -3.4* camber. Got some "crash bolts" and was able to play with caster & camber to help reduce it. It helped but im still at -2.6*. If you want less than that, you'll need the K-Macs.
Merc dealer wont be able to do much more. Get the bolts and get it realigned.
I've lost track of how many rears I've gone through now and I had the same front issue once, but the alignment was near spot on.
Together: 0°16' ± 0°07'
Left: 0°08' ± 0°07'
Right: 0°08' ± 0°07'
Edit: might as well post the front toe-in, might be useful in this thread. Front toe-in:
Together: 0°14' ± 0°10'
Left: 0°07' ± 0°05'
Right: 0°07' ± 0°05'
Mine is going to alignment on Monday and I told the guys to use the minimum specs. Should I tell them something else?
