Could only Mityvac out 7.5 L of oil, am I ok?
Oil was fairly black looking too. In a few thousand K, Should I go to a shop and let them drain it?
That's fine. You most likely burned 1.5l of oil and 1l remain in your oil cooler. Just keep a watchful eye on how much oil you're putting back in.
The rest is in the oil cooler
Did mine the other day and had like 8.2.
For reference, I do my oil on the 5K interval and have the dealer do it on the 10K interval. This way, the dealer is dropping the oil from the bottom. I do the quickie from the top. I wouldnt recommend doing all your oil changes using the mighty vac, regardless of interval.
86 Targa, 91 560SEL, 06 E55 Estate, 13 C2S, 21 MACAN GTS, 05 R6 Track, 15 R3 RACE BIKE
Some of the other members have reported that dealers also use a similar process as the mityvac so, your dealer may not be draining from the bottom. 2cents
