Blackstone UOA Thread
Most recent Blackstone analysis came back today. Couldnt be happier with the results. Idk how I feel out pushing out to 12,500, but its nice to see theres plenty of protection left in the oil.
Car is DD and frequently gets up to 240/248*F. This last oil sample had a 1/2 mile drag event as well.
The main purpose most folks use UOAs for is to maximize the oil life for their heavy duty commercial vehicles and fleets so the primary thing they look for is the TBN and how much oil life is left. Agree 100% that for performance and personal applications changing it more frequently is the best insurance money can buy.
https://www.toromontcat.com/service/...alysis-program
Breakdown:
2014 C63 M156
Car purchased 12/2016 with 2500 miles
OC#1 / Sample #1 - Taken @ 7500 miles. Oil had +5K on it. This was the original oil from my purchase.
OC#2 / No Sample - was done at 12,000mi. Oil had +5K on it. M1 0w40 used
OC#3 / Sample #2 - was done 16,500mi. Oil had +5K on it.
OC#4 / No Sample - was done at 22,000mi. Oil had +5K on it. M1 0w40 used
OC#5 / Sample #3 - was done at 28,500mi. Oil had +6K on it.
Yes I know my lead is still high - using 100 octane unleaded (supposedly) at the pump regularly.
Great UOA Jim. I love the new Rotella T6 formulation and am now running it in my C63 and the 928GT. Plenty of ZDDP for flat tappet engines and good viscosity especially when it gets hot. The lead is almost definitely from the 100 octane "unleaded" race fuel.
Cheers,
Doug
Will be continuing with Oil Analyzers (partnered with Amsoil) going forward and likely changing/testing every 2 track days. Maybe bump it to 3 depending on results.
This was my latest one I posted in the T6 thread. It was a partial summer, full winter and one track day. Gotta keep an eye on that nickel number. Maybe time for new cams and buckets soon.
Molybdenum was higher in the Liqui Moly than T6
but
Zinc was higher in T6 than Liqui Moly.
Out of curiosity, anyone try the 0W-40 version of T6?
but
We never changed the oil on them as they somewhat changed their own continuously by leaking it onto the ground or blowing it up the stack. Typical usage was about 2.5 gallons per day. With a crankcase capacity of about 350 gallons we would send out samples annually and the lab would send back a 5 gallon bucket of concentrated additive to put in the sump when we swapped out the filters.
I should start sending samples out for my cars.
Right now I am thinking 4 track days.
As it sits now with all the cooling modifications I have done, on a hot humid day my oil peaked at 126°C on a short tight track.
Will look into the Millers, thanks. Is the CFS 5w40 NT+ something you'd run in your M156 if it was track only? What about winter storage (heated garage) and leaving a pure ester base stock in the pan?
A lot of current AMG GT3s are running it, so I would think that if it's is OK for the M159 in the AMG GT3, it wouldn't be any different in our M156 - it's the same engine but without the dry sump.
