Spark plugs with headers?
My car runs at high rpm and high load for most of its life. I like the colder plug for this reason. It is 100% unnecessary for a primarily street-driven car because it won’t burn hot enough to get rid of deposits. Especially in stop-and-go traffic it will perform worse.
I guess it doesn't hurt to run the new oem plugs I bought from RM and go colder if I have to, it's not exactly the hugest expense to swap.
All that aside, my point was that my best local gas is going to be vpower 91 and it's not as good as the 91 in the USA, and 94 octane isn't even an option here. I can't technically run a "94 octane tune" on the chevron 94.
In the aeronautic field, they monitor not only the EGT, but also the CHT.
The CHT is the cylinder head temperature.
For my Subaru, I bought a 4 channel CHT rig for around $200.
It includes a very nice gauge and 4 thermocouples.
I was trying to use the rig to change settings in the tune, to change per cylinder fueling, to make it more evenly loaded. One cylinder was constantly colder... i deviate
Anyway, the way the rig is mounted is you use silver solder to solder the thermocouple tip to the spark plug washer (back side). Then you route the thermocouple wire out of the well, sneak it past the rubber boot of the coil pack and past the coil pack, then bring it to the gauge.
You get very accurate readings of temperatures by the spark plug and NGK has a diagram with coefficients that allow you to infer the temperature by the tip.
Then you could look that up in different tables and factually know if you need colder plugs......
I didn't think to look into changing the plugs on the Subaru, was only worried about fueling.
