What is normal compression on a p31 car?
After talking to taso over in the middle east he said car should see 170psi on semi hot engine.
I just did 3 cylinders and I'm getting 212 psi on each so far.
if this is high it can explain why my car dosnt like anything over 25 degrees timing
Looks like your compression is on the low end but could be temperature related.
Not sure where Taso is getting his number from but 170psi (at operating temp) seems to be very low and should trigger a leak down test.
At 80C (176F) it should be between 14bar (203psi) and 18bar (261psi). Difference between cylinders shouldn't exceed 2bar (29psi)
Do you know the numbers on a cold engine? I can test that easily now
Due to the Piston expansion it can vary from 10 to 15 psi on cast pistons. The P31 engine having forged pistons that could be different in most cases. Forged pistons have a higher expansion rate and therefore the pressure difference in a P31 car between cold and warm could be higher.
I would perform the test at operating temperature to be sure.
That is hard to say per Mercedes the test has to be performed at operating temperature.
I'll have to retest when it's back together
You can continue to perform it cold and go for the pressure difference between each cylinder. I would say 212 on a cold engine is pretty good.
I’m not sure if your compression can be too high.
I have nerver seen an engine with a too high of a compression. But that is just what I have seen so far.
