Coupe vs Sedan Suspension Differences?
Hi all - I searched a bunch but it didn't look like anyone could say definitely one way or the other. Wondering if anyone knows 100% if the w204 C63 Coupe and Sedan have interchangeable suspension components? Currently running coilovers, camber plates, and some custom sway bar end links and considering going back to stock altogether. I no longer have the stock suspension components on my sedan and someone locally is offering their stock setup from a coupe but I wasn't sure if that would work. Thanks for looking!
Should be the same. H&R springs are the same part numbers for the coupe and sedan. Someone else confirm?
Ya I saw that the part numbers on those was the same. But then I also saw that most coilover vendors such as KW list different part numbers for sedan and coupe for something like their V3's...
hmmm...I have a 2010 sedan on H&Rs. what kind of swap are you looking at doing? I am in CA also.
I am removing my BC Racing coilover setup and going back to stock. I don't have the stock suspension but somebody local has stock suspension from a coupe. Just trying to find out if that will bolt right up before picking it up and giving it a shot.
So instead of starting a new thread and I've looked around and couldn't find an answer... But do the KW V3 coilovers for a coupe fit on a sedan?
On the KW website they have different part numbers for a sedan and for a coupe.
Someone locally is selling their V3s for a good price but its off their coupe and I own a sedan. Can anyone confirm that it will fit no problem?
Thanks,
Thanks,
Thanks,
Thanks,
