C63 AMG (W204) 2008 - 2015
Daytime Running Lights Replacement
Old Sep 26, 2018 | 12:56 PM
jloh_atx's Avatar
2012 C63
Hey guys,
My passenger side daytime running LED lights have gone out. It was cracked for awhile and I think the moisture caused it to finally go out. It flickered for awhile, then finally just stopped lighting up. Here's a pic of it lit up on my car before it went out:
What part do I need and how hard is it to replace?
I called Mercedes dealership and from my explanation they said the part number is 204-906-49-02. Should I just get it from Amazon below, does that look to to be correct part? Open to suggestions.
Amazon Amazon
AutoHauz
MercedesPartsHub
Appreciate the help!
Old Oct 21, 2021 | 06:06 PM
Cahlheim's Avatar
C63 AMG
I know this is an old thread, but did you end up replacing these yourself? If so, what ended up being the right part number(s) and any tips you can pass along?
Old Oct 23, 2021 | 10:25 PM
SDR's Avatar
SDR
'99 C43, '12 C63, '13 E350, '14 Sprinter
2049064902
I bought the pair for ~$210. You could probably find one cheaper, but mine were both rock chipped in addition to the broken one. I added a strip of vinyl protection to them before installing just for extra resilience.
Because I also wanted to respray my bumper, I used that as an opportunity to pull the whole thing off which made replacement easier. Much easier. I don't know if I could have replaced it with the bumper on. The drivers side, definitely not.
https://mbworld.org/forums/c63-amg-w...ement-diy.html
