LED DRL replacement DIY?
My left DRL is inoperable. I haven't found a write up, but several mentions of removing the front bumper to access the DRL.
ive successfully removed the bezels but it didn't appear that there was access to the mounting hardware for the DRL assembly.
Can anyone point me in the direction of an existing DIY, or even just let me know if bumper removal is 100% required for DRL replacement?
Thanks,
Thanks,
From what I remember when I replaced mine. I had to use multiple long flat head screwdrivers at the same time in order to pop off the clips that held the DRL in place. If you put a flashlight on the top and bottom of the DRL, you can see where you need to put the screwdriver. There are 2 on top and 2 on the bottom. If you try to do one at a time then after you release one clip and move to the next one, the one you just released will pop back into place. Use multiple screwdrivers to release the clip and leave the screwdriver in place holding the clip open.
The DRL comes out from inside the bumper. You cant remove it by pulling it out from the front. From underneath the car, remove splash tray, unbolt the horn and move it aside, that gives you enough room to get your hands in there and pull the DRL out.
i thought I had read that the drivers side was more difficult, but I'm happy to hear otherwise.
My passenger side is shot and the oil cooler and such is in the way.
Anyone have directions for that side, or full bumper removal?
i just put my order in for my 44O cooling upgrade and I'm going to try to tackle it myself. The first order of business will be removing the front bumper cover without breaking anything.
There is enough room to pull the bumper away from the body to get your hand in there and pop the clips.
Ive got install instructions for the 44O kit. They aren't perfect, but they should hopefully be enough to get the job done. we'll cross that bridge when we find out my kit is on the way. I may change my mind and have a local shop do the install.
Thanks!
