C63 AMG (W204) 2008 - 2015
Dyno numbers for W204 C63 AMG with E-85
Old Dec 6, 2018 | 04:32 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
i have a question....it seems the flexfuel unit converts injector time from gasoline to the appropriate mix dependent on ethanol sensor reading. the question i have is...since ethanol air fuel ratios are different than gasoline, how does the factory computer cope with this? I would think the computer will be thrown all out of whack since its o2 readings are much lower than with gasoline.
Normal gasoline has a stoichiometric air fuel ratio of 14.7:1, while E85 is 9.8:1. 'Stoichiometric' is a chemical term that refers to the required ratio of fuel and air for complete combustion. Again, if you failed chemistry this means that on pump gas we need 14.7 parts air to mix with one part fuel.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Dec 9, 2018 | 10:18 AM
Brasilianer87's Avatar
Max Power: 491.3whp
Max Torque: 483.5 lb-ft
491whp is a pretty good number already. If you still have room to make it 500ish (maybe more), then it's areally good mod, since it keeps the car 'OEM' and you don't have to drop a 18 wheeler of cash as investiment.
What happens if you decide to use only petrol then? Car behaviour changes a lot?
Old Dec 10, 2018 | 05:07 AM
Texas E63's Avatar
Built 2008 G55 & one big 80 Series LandCruiser !
Jerry worked with ECATX to tweak the tune a bit for my extra mods and got it to 517rwhp - hard to know which of them helped the most but I suspect the Renntech airboxes and underdrive pulleys freed up a decent amount of it.
File Type: mov
Old Dec 10, 2018 | 08:47 PM
Celicasaur's Avatar
W212 - E63 AMG
We're going to need to see a nice thread with more details man...that is just awesome. The top end must be super satisfying at WOT!
